Old 08-08-2016, 08:26 PM   #1
Tow truck over heating
Ok traveling toward Seattle right now just a bit east of Denver. I'm pulling my 02 Salem 28.5 with my 03 2500 HD Silverado. Over heats & dies this is after a new Thermostat & water pump
Stuck on RV spot in Hudson Co.
What's wrong...?
Louisiana Irishman is offline   Reply With Quote
Old 08-08-2016, 08:28 PM   #2
Radiator partially plugged.
donniedu is offline   Reply With Quote
Old 08-08-2016, 08:46 PM   #3
Blackhat6mike's Avatar
Just because the thermostat and water pump are new doesn't mean they are GOOD. I've seen thermostats installed upside down and because the people doing the work didn't know how to properly refill the radiator step by step. Instead, they partially refilled it and sent the owner on his way.
Still, it wouldn't hurt to have the radiator flushed especially if you haven't been changing the coolant regularly. I personally flush mine every other year and add new coolant.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 08-08-2016, 08:48 PM   #4
Ohhh I totally forgot about the need to properly burp a Duramax cooling system.
Old 08-09-2016, 01:18 AM   #5
Retired
RubyDually's Avatar
Cooling stack is likely plugged up with 13 years of bugs and other road grime...
http://www.trucktrend.com/how-to/eng...cooling-cores/
2014 Chevrolet Silverado 3500 LTZ CCLB DRW D/A - Rancher Grille Guard - Transfer flow 40 gallon Toolbox/Tank Combo - Line X - Edge Insight
2015 Palomino Sabre 33CKTS - Platinum Edition - Progressive Industries EMS HW50C - JT Strong Arm Stabilizers - Ground Control 3.0 - 320 Watt Solar with 2000 Watt Inverter
RubyDually is offline   Reply With Quote
Old 08-09-2016, 04:26 AM   #6
nomad297's Avatar
Fan clutch
Bruce
Old 08-09-2016, 12:40 PM   #7
Left Coast
Turn heater on, start truck without radiator cap on, let warm up, and add as necessary...
Old 08-09-2016, 01:49 PM   #8
rsdata's Avatar
13 years on an original radiator pulling heavy in the mountains is asking for trouble...
Too much of anything is bad, but too much good whiskey is barely enough. Mark Twain
2014 Shamrock 183
Old 08-09-2016, 01:51 PM   #9
mike.t's Avatar
If it has a cap on the radiator start up the truck when it reaches about 197 you should see the water moving in the radiator. If the stat is open the water should be moving if it is not could be the thermostat.(doubt it has a defective thermostat)
2009 Ram 3500 Mega Cab
2018 Wilderness 2450FB
2014 Dodge Durango
"If you can't fix it with a hammer, you've got an electrical problem"
mike.t is offline   Reply With Quote
Old 08-09-2016, 02:25 PM   #10
Remove cap whn cold, let it idle and look foe bubbles= combustion getting into coolant. Gasket, crack in cyl head or block. Just an idea
pdqparalegal1 is offline   Reply With Quote
heating, truck
