My previous truck was a 2009 GMC Sierra crew cab 4WD with 5.3 engine and towing package. It towed my ROO 23SS fine, but, I knew it was back there on the hills.
I was comfortable towing and within all my numbers. My Roo weighs 4,500lbs. from the factory......add in propane, battery, full tank of water and all the gear in the trailer and I'm probably shy of 6,000 lbs.
You really need to look at your numbers, truck and trailer and toy or cargo. If your numbers support towing the trailer, you probably will have as much trailer as you would want.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
