Old 02-09-2019, 05:50 PM   #1
Tow Vehicle
Looking to purchase a used F350 SRW diesel for a tow vehicle. Which model year in your opinion was better? and why? Model year 2016 thru 2018?
Halifax Jack is offline   Reply With Quote
Old 02-09-2019, 05:53 PM   #2
I don't know which is better but wasn't the Super Duty completely redesigned in 2017? I'd choose a last year model over a first year model because all the bugs and recalls are worked out.
2010 Nissan Frontier Crew Cab long bed 2WD (sold)
2019 Forest River Surveyor Legend 19BHLE
upflying is offline   Reply With Quote
Old 02-09-2019, 07:41 PM   #3
007matman's Avatar
Probably' 17 or '18.. as others have said stay away from the first few years of anything.
007matman is offline   Reply With Quote
Old 02-09-2019, 08:30 PM   #4
clarkbre's Avatar
The 6.7 in recent years has been a very good engine as the emmisions bugs have been worked out.
Model years '11-Current have any transmission you want....as long as it's Ford's 6 speed 6R140. This transmission has proved to be very good behind the diesel and gas motor. The '17 and newer F250's with 6.2 gasser has the 6R100 that is basically the newer 6r140 with gearing of the 1st generation F150 Ecoboosts.
Looking at late model Fords with the 6.7, I would say just avoid (not drastically like certain engines or tranny's) the '17 model year as that was the first year of the redesigned "new generation" aluminum body. the 1st year of any new generation is kind of a case study for any and all manufacturers. There is nothing inherently bad about the engine or tranny but there may be some odd things that was changed in the '18 model year.
What are you looking to tow with it?
2017 Forest River Surveyor 247BHDS...
...Tugged by a 2016 F250 XLT FX4 SuperCrew, Shortbed 6.2L, 4wd, 3.73...
...Joined with a Husky Centerline TS 800-1200lbs WDH
clarkbre is online now   Reply With Quote
Old 02-09-2019, 08:32 PM   #5
Now a "Top Member"
EdJunior's Avatar
2017 changed the design of the body. Mostly the front and back end, and the interior. The engine and transmission are essentially the same, with the improvements made since their introduction in 2011, including a slight power boost. So if you want the design changes, go with a '17 or '18. The 2011 - 2016's were all the same body style.
I have the 2019, and it is a fantastic truck. My 2011 engine died prematurely, and I have to believe they have all the initial design issues fixed. It's a great truck.
Ed and Sharon
2010 Wildcat 28RKBS
2019 Ford F-250 XLT - Still too new
Old 02-09-2019, 09:31 PM   #6
clarkbre's Avatar
Originally Posted by EdJunior View Post
.... My 2011 engine died prematurely, and I have to believe they have all the initial design issues fixed....
Funny....my '11 Ecoboost (1st year) had a catastrophic failure (failed waste-gates in the turbos blew the exhaust manifolds off the block) at 71k miles. Ford said it was a "Doozy" of a problem. Although it was fixed, they couldn't tell me WHY it happened and didn't guarantee that it wouldn't happen again. Sold it.
Thankfully, my VERY understanding wife, allowed me to get the '16 F250 6.2L crewcab in my signature. I love the truck and will never have anything less than a 3/4 ton for towing an average sized trailer. I also will never buy a 1st (or even 2nd or 3rd) year engine again. I like that the 6.2L (along with the 6.4L) has been tested in the real world since 2011. The '14-'18 seem to be a good era for the Super Duty trucks.
Old 02-10-2019, 05:21 AM   #7
BigH's Avatar
2016 unless you live someplace there is no winter.
After 2016 you get the aluminum body and Ford has a problem in cold climates with doors that will not unlock / doors that will not latch closed if you do get them unlocked with the aluminum bodied trucks.
This problem started the winter of 2014 with the 2015 aluminum bodied F150 and carried over to the aluminum bodied f250/350 in 2017. The first winter the problem showed itself Ford had parts on back order until spring. The next year proved the new parts didn't work and parts went on back order until spring...repeat. Repeat. Repeat until now and they still don't have the problem fixed.
This problem is large enough that there were more than 20 vehicles waiting for parts at my dealership according to the service manager. He told me it was the same at every dealership that has temps getting below freezing.
Here is a link to the F150 sticky thread on this subject. This thread has been restarted several times because it became too large.
https://www.f150forum.com/f118/2015-...thread-435339/
It is absolutely horrible to have a truck in the driveway that you can't use in the winter...
17 Chevy 2500 DC Long box Gasser Z71 4.10
18 Vengeance 28V
BigH is offline   Reply With Quote
Old 02-10-2019, 08:14 AM   #8
5er_tom's Avatar
I have a 2012 F250 for sale. It is listed here on the forum. It is an extended cab, 4x4, short bed with the 6.7 diesel. The diesel is a new 2018 engine that was installed by Ford after the original engine self destructed. Take a look. It will make someone very happy. I towed a 10,000# and then a 13,000# fifth wheel with it. A great tow vehicle.
Tom & Renée
Durham, NC
2015 Wildcat 295RSX
2018 Ford F-350, 4x4, Diesel, CC, Long Bed
5er_tom is offline   Reply With Quote
Old 02-10-2019, 11:27 AM   #9
Tow Vehicle
I owned a 2016 my biggest disappointment was turning radius the day I bought my dually I test drove a a used swd 2018 350 for my short test drive cab felt bigger and the turning radius felt tighter might have been me looking for reasons . In my honest opinion you probably need to find a dealer with both style and compare side to side
moose074 is offline   Reply With Quote
Old 02-10-2019, 02:11 PM   #10
Retired JSO's Avatar
Tow Vehicle
If the 2018 was a crew cab, 2017-18 is bigger by 3”.
Retired JSO is offline   Reply With Quote
tow vehicle
