Old 06-19-2019, 05:16 PM   #1
Gnuters's Avatar
Tow vehicle
Iím sure this has been asked 1,000 times but.... I just bought a 2020 Cherokee 264DBH dry weight is 6,760 and gross is 8,585. My tow vehicle is a 2008 Ford Expedition EL gross tow cap is 9,000. Everybody says I should be ok pulling this, I have WDH. Any thoughts??? Thank you
Gnuters is offline   Reply With Quote
Old 06-19-2019, 05:25 PM   #2
bikendan's Avatar
You need to look at the Expy's Payload Capacity due to the heavy loaded tongue weight of that trailer, not the towing capacity.
You'll always run out of payload capacity WAY before reaching that 9000 number.
Equalizer WDH
Old 06-19-2019, 05:32 PM   #3
Gnuters's Avatar
Payload is 1,697 to 1,745
Old 06-19-2019, 05:38 PM   #4
fonzie's Avatar
Post you yellow sticker from your driver door jam. example below
Name:	Ford door jam stickers.jpg
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 06-19-2019, 05:41 PM   #5
Grammar Pedant
67L48's Avatar
It has been asked a 1000 times and the answer is the same every time: tell us your payload and tell us who/what else is in the TV with you.
Payload isn’t a range, it’s a single specific number. It’s on the door jamb (not to be confused with door jam, which I think is for door bread) sticker of your TV.
You’ll have 1,000 lbs on your TV from the trailer alone. Family of 4 weighs in around 600 lbs, for average people. WDH will be 50 lbs or more. And there will be other items in that rig. Pets, gear, etc.
Probably north of 1,700 lbs. But, again, it all depends on the details.
RV: 2018 Rockwood Mini Lite 2504S
67L48 is offline   Reply With Quote
Old 06-19-2019, 05:45 PM   #6
Gnuters's Avatar
Originally Posted by 67l48 View Post
it has been asked a 1000 times and the answer is the same every time: Tell us your payload and tell us who/what else is in the tv with you.
Payload isnít a range, itís a single specific number. Itís on the door jamb (not to be confused with door jam, which i think is for door bread) sticker of your tv.
Youíll have 1,000 lbs on your tv from the trailer alone. Family of 4 weighs in around 600 lbs, for average people. Wdh will be 50 lbs or more. And there will be other items in that rig. Pets, gear, etc.
ID:	207788Click image for larger version
Old 06-19-2019, 07:20 PM   #7
Dry hitch weight is 880 and your payload is 1,580. That leaves only 700 pounds for the WDH, passengers, food, gear, water, pets, or anything else in the TV plus the TT options, batteries, and anything else that adds to the tongue weight. As the others mentioned, you'll run out of payload long before reaching towing capacity.
2019 Rockwood 2902WS
2019 Ford F250 4X4 CCSB 6.2/4.30
Equalizer E2 with single old-school friction sway control.
woo10-210 is offline   Reply With Quote
Old 06-19-2019, 07:23 PM   #8
Gnuters's Avatar
So your saying I should get a bigger vehicle? Like a F-150 dealer said a F-250 would be overkill for that trailer
Old 06-19-2019, 07:30 PM   #9
rsdata's Avatar
dealers lie all the time... consider them to be worse then used car salesmen
Someone mention dry hitch weight... your trailer was dry when it left the factory, then they added a battery and a couple of propane tanks and you add even more stuff... so add at least 200# to the dry weight number and probably even more for the tongue weight... you will be over 1000# before you know it.
Figure you only load trailer to 8,000#... take between 10-15% to figure hitch weight... bigger number is more stable when towing... so 13% of 8,000 is 1,040# of tongue weight. Look at your Esp manual and see if you can even put 1000# on the tongue, even with WDH
ďToo much of anything is bad, but too much good whiskey is barely enough.Ē Ė Mark Twain
2014 Shamrock 183
Old 06-19-2019, 07:34 PM   #10
Gnuters's Avatar
Thank you
Old 06-19-2019, 07:36 PM   #11
bikendan's Avatar
As you can see, your actual payload is quite a bit lower, than the lower number of that range you posted.
Its always advised to actually weigh, at least your Expy, to get a true curb weight number. Then subtract that from the Expy's GVWR number. That will give you a true Payload amount.
A F150 3.5 EcoBoost with the Max Tow package, would work great with that TT, IF you stay away from those fancy bling trim levels. Like the Platinum or Lariat.
Equalizer WDH
Old 06-19-2019, 08:02 PM   #12
Yup heard the same things and I thought I did my home work. By the book my numbers on my half ton worked. But after a year of trying everything to make it work, look at me now with a F250. 8800 lb gross TT and 1200 lbs of tongue weight. Our very first mile we knew a bigger truck was the right move. I was an accident waiting to happen, I guess it did happen only there was nothing there to hit. My TT pushed my truck around whether I would admit it or not. I finally accepted defeat traded for larger truck. Oh, the TT was advertised as half ton towable by the salesman.
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
uhduh camping is offline   Reply With Quote
Old 06-19-2019, 08:05 PM   #13
Gnuters's Avatar
Would you go diesel or gas?
Thank you for your advice
Old 06-19-2019, 08:20 PM   #14
Multi-Slacker
My TT GVW is 8818. @ 15% the hitch weight could be 1350 lbs. Moved to a 2018 Chevy 2500HD gas with 4:10 rear. Runs up and down western mountains quite well. Since my payload on the truck is 3343, I have lots of room left even after maxing out the TT's GVW.
2017 Forest River Sonoma 280RKS
2018 Silverado 2500 HD 6.0L, 4:10 rear
Prodigy P3 Brake Controller
Andersen WDH / 2700 lb 2.5" Receiver
CurtPutnam is offline   Reply With Quote
Old 06-19-2019, 08:23 PM   #15
clarkbre's Avatar
Here we go! Grab the popcorn!
2017 Forest River Surveyor 247BHDS...
...Tugged by a 2016 F250 XLT FX4 SuperCrew, Shortbed 6.2L, 4wd, 3.73...
...Joined with a Husky Centerline TS 800-1200lbs WDH
clarkbre is offline   Reply With Quote
Old 06-19-2019, 08:41 PM   #16
Gas, wish I could go diesel sometimes usually when its time to fuel up. Diesel pumps are easier to get to.
Hensley Arrow
Old 06-19-2019, 09:39 PM   #17
Maticuno's Avatar
Depends on the manufacturer. Ford makes great gas engines for the 3/4 ton trucks. Chevy, not as much. Diesel is the only way to go with a Ram.
ďHere is your country. Cherish these natural wonders, cherish the natural resources, cherish the history and romance as a sacred heritage, for your children and your children's children. Do not let selfish men or greedy interests skin your country of its beauty, its riches or its romance.Ē - Theodore Roosevelt
TV: 2003 F250 V10 4X4
TT: 2019 Wolf Pup 18TO Black Label
Maticuno is offline   Reply With Quote
Old 06-20-2019, 04:26 AM   #18
Grammar Pedant
67L48's Avatar
Would you go diesel or gas? [...]
Depends on a lot of things that youíre still not sharing. How many people in the TV? Other gear, bikes, etc.? Camping habits? You towing the flat beaches of the gulf coast or 11,000í Rocky Mtn passes? And, so on.
The more info you provide, the better people will be able to help.
Old 06-20-2019, 04:34 AM   #19
Gnuters's Avatar
2 adults 2 children in Wisconsin donít pack too much stuff
Old 06-20-2019, 06:27 AM   #20
North to Alaska's Avatar
Talk to your insurance rep and get the $ amount that you are covered for in towing a trailer. Go back to the dealer with the proof of that coverage. Ask to test drive the trailer (if they are so da#% confident). Removes the "can't let you test drive because of insurance" excuse. (Haven't tried this yet so let me know if this works. )
Wisconsin has lots of fun hills to test it on.
If it pulls fine, maybe just upgrade your brakes and get a dedicated transmission oil cooler.
Sway control is usually a matter of WDH brand and quality.
Most states have no laws about going over the tow rating and most insurance will still cover you.
North to Alaska is offline   Reply With Quote
tow vehicle
