Old 02-13-2014, 02:03 PM   #1
Tow Vehicle engine noise - Normal???
I just purchased a 2001 Chevy 3500 with 6.6 Duramax. This is my first Chevy diesel and it just seems to be loud inside truck while towing. The sounds is almost like a gas engine low on oil. Kind of a knocking sound. Is this normal sound for this engine? Tks!!!!
Cardinal camper is offline   Reply With Quote
Old 02-13-2014, 02:21 PM   #2
avolnek's Avatar
Typically they will make more noise, a duramax shouldn't be as noisy as a cummins by any means.
There is a line though where too much noise isn't right... Any way you could post a video of what you are hearing and or concerned about? Hard to verify without actually hearing it.
Something to remember is a diesel creates a LOT More pressure inside the combustion chamber so things WILL rattle. Speaking of the cummins at least, my fuel injectors are running in the neighborhood of 7,000 psi at an idle and up to around 20,000 psi at full throttle! things are going to make noise!
TV- 2015 Ram 2500 CCLB 6.7 Cummins 3.42 gears
Camper - 2015 Saber 322BHTS
avolnek is offline   Reply With Quote
Old 02-13-2014, 02:39 PM   #3
Brother Les's Avatar
You would get the best answer on a Chevy truck forum from owners that have had your type of truck for many years. I have owned my Diesel for 10 years and I would swear that it 'sounds' different every time I get in it. Sometimes smooth as silk and sometimes rattles and rocks. Pulling a load will change your RPMs and shift points a little. Have you had a chance to change your oil and fuel filter out for new? The Diesel fuel is a winter blend and will change things a little. Does your truck have a Chip or Tuner? There are different tow modes that will in a sense change 'the sound' of your diesel. You may have to pull your valve covers and re torque your rocker arms and injectors. There are many other little tweeks that may need to happen that the former owner has not kept up on.Don't know a whole lot about your Duramax, but I know that it is a very fine engine and truck. Learn as much as you can from a Chevy forum and you will be having a perma grin all of the time....
Brother Les
Old 02-13-2014, 03:09 PM   #4
hrlyguy2's Avatar
Since you have a lb7 motor.They are common for bad injectors..I would have your balance rates checked.I have alot of friends with lb7s alot of them use a quart of 2stroke oil tw3.which is a ashless oil to a tank of fuel to help with lubrication.
Can get a good additive too at Napa to clean up injectors
2007.5 Chevy 3500Ltz cc lb Duramax
2010 Sandpiper 345 RET (SOLD)
hrlyguy2 is offline   Reply With Quote
Old 02-13-2014, 07:10 PM   #5
Chewie's Avatar
Is it the pilot injection shutting off at a certain rpm?
I used to have a really nice motorhome
2016 Jeep Wrangler Unlimited
Chewie is offline   Reply With Quote
Old 02-14-2014, 11:31 AM   #6
I would expect a 2001 Chev diesel to be nosy.
whj77372 is offline   Reply With Quote
Old 02-14-2014, 11:47 AM   #7
jevanb's Avatar
since you have a 5 speed and sitting @2k or better towing heavy 65MPH it is going to be louder then a gas motor at that RPM, if you remove your foot from the pedal does the noise go away some??? as these engines evolved they also got quieter, I would agree on the valve train need adjusted, the inj are 200k warranty and it sucks to replace them, most LB7`s have had them done before that also, check the bal rates with a scanner should be <>4.0 and do a injector return test, go to Chevy and GMC Duramax Forum and do a search
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 02-15-2014, 06:43 AM   #8
I owned an LB7 for several years, it was my first diesel. As other have stated the injectors are prone to problems. An injector in my truck failed and caused over fueling which in turn cracked a piston. Please be proactive and have those balance rates checked. A new diesel motor is not a cheap undertaking.
2013 Silverback 35QB4
2008 F250 6.4 Powerstroke
SCT & Gearhead Tunes, Hellwig Progressive load leveling springs
ckehl2 is offline   Reply With Quote
Old 02-16-2014, 10:32 PM   #9
dsrace's Avatar
good info and I have 4 friends with duramax's and they all started using 2 stroke oil and it did quiet the inj's down to the ear. I put rev x in my ford
'99 f350, quad cab long box, dually, 6 speed manual, gently mod'd.
2011 wolf pack 295 with full susp now!
dsrace is offline   Reply With Quote
Old 02-16-2014, 10:34 PM   #10
dsrace's Avatar
that's no joke they are very expensive especially if you can't change it yourself
tow vehicle
