Old 10-27-2011, 10:47 PM   #11
TURBS's Avatar
Originally Posted by Taranwanderer View Post
I would check on the transfer case in neutral thing. I don't know what Dodge is using (t-case wise) in their trucks lately, but some of those NP cases actually lock the front and rear driveshafts together when it's in neutral-it just disconnects it from the tranny. It'll sound real funny going around corners if the front and rear shafts are locked, not to mention major u-joint wear. I used to flat tow my Jeep before I went the tandem axle car trailer route.
I agree !
I would just call your dodge dealer THAT is your best bet !
DO NOT just take someones word for it .
Old 10-28-2011, 07:17 AM   #12
2011 Berkshire 390bh
wnytaxman's Avatar
If you check out the Family Motor Coach Association web site, you'll find a listing of all the various vehicles and the towing info from their manufacturers. There are other sites as well to help you. I don't think you need the tranny cooler, but check out the listing on FMCA. You may have to join, but they're a good group so it's worth it.
wnytaxman is offline   Reply With Quote
Old 10-28-2011, 04:42 PM   #13
sherdep's Avatar
He cant put his transfer case in Neutral - he has the push button 4 wheel drive
My parents belong to Family Motorcoach Association - they go on alot of outings during the week too and my parents like the group of people they hang out with so worth a shot like wnytaxman said
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 10-28-2011, 05:32 PM   #14
bikendan's Avatar
if the truck has the factory tow package, it came with a factory tranny cooler.
if it has an added aftermarket hitch, then it probably doesn't have the factory tow package and doesn't have the tranny cooler.
either way, don't know why the OP would need one installed on the truck, if he's using it as a toad.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 10-28-2011, 05:58 PM   #15
M109Rrider's Avatar
All 1500 dodges with the hemi have factory tranny coolers....but it doesn't do anything unless the engine is turning the pump and moving the fluild. You can't just put the trans in neutral, parts of the tranny will be rotating without lubrication. If you can't put the t-case in neutral and don't want to disconnect the driveshaft I think the best thing would be to find a different toad.
Jason and Billie
2005 Dodge Ram 2500, 4X4, QC/SB 5.9L Cummins
15k non-sliding Hidden Hitch (they lied, it's not hidden at all)
2011 Prime Time Crusader 320RLT
M109Rrider is offline   Reply With Quote
Old 10-28-2011, 07:01 PM   #16
flyrotor's Avatar
The ram 1500 can be towed as a toad, I don't know what components it need, but I have seen several behind motorhomes.
Do what sherdep suggested and check the dodge forum for other dodge owners.
flyrotor is offline   Reply With Quote
Old 10-28-2011, 07:18 PM   #17
TURBS's Avatar
I have push button four wheel drive . You just push 4 lo and 4 hi at the same time to put it into neutral. No biggie
Old 10-28-2011, 07:19 PM   #18
Wanna Be Camper
SaskCampers's Avatar
Here is the proceedure to shift an electronic 4x4 dodge transfer case into neutral.
1: stop truck
2: shut off engine
3: turn key to on but do not start
4: depress brake pedal
5: shift auto tranny in neutral or depress clutch on manual
6: using the point of a ballpoint pen depress the recessed transfer case neutral button for 4 seconds (below the 4x4 selector knob and to the left of it)
7:after shift is completed and neutral light comes on release neutral button
8: start engine
9: shift auto tranny into reverse
10: release brake pedal for 5 seconds and make sure there is no movement
11: repeat steps 9 and 10 in drive
12 shut engine off and place key in unlocked position
13: shift auto tranny into park or 1st on a manual tranny
14: apply park brake
15: attach truck to tow vehicle
16: release park brake.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 10-28-2011, 07:23 PM   #19
Wanna Be Camper
And to reingage it
1: stop truck
2: shut off engine
3: turn key to on but do not start truck
4: press brake pedal
5:shift auto into neutral or push clutch on manual
6: ball point pen and press recessed transfer case neutral (N) button for 1 second
7: after neutral indicator light goes out release neutral button
8: after the neutral button is released the transfer case will go into the selected position on the switch
9: shift auto tranny into park.
and there you have it, no kits or $$ thrown away.
John & Deb
Old 10-28-2011, 07:46 PM   #20
sherdep's Avatar
Now thats some good info and I learned something new - I was unaware you could put a push button 4 wheel drive in Neutral
Good find of info guys
I could have searched for it but since I have the shifter on the floor to put the transfer case in Neutral - I never thought to look it up myself
