Old 11-11-2009, 01:49 PM   #1
Tow Vehicle Question
Hello,
I am new to this forum. We just purchased a 2010 Wildwood with a 21 ft box and 500lb tongue weight. It has a dry weight of 5006 lbs. We are now looking at used vans (Chevy Express, Savana, Econoline etc) for towing. A 2500 with a V-8 has a towing capacity of 8600 lbs. From what I can gather on a 1500 V-6, it has a 6400 lb towing capacity. I am leaning toward the V-8. DH is leaning toward the V-6.
I would like opinions pro and con on these 2 options.
SUVs and pick-ups are not an option because we travel with dogs and gear.
Thanks in advance
Cheri
3bcs1jrt is offline   Reply With Quote
Old 11-11-2009, 03:40 PM   #2
Get the V8. In the long run, you'll be much happier. Less work for the vehicle to tow the trailer translates to better gas mileage when towing- plus something else to consider is the 8 will have a beefier transmission, and springs, trans. cooler (hopefully), a bigger radiator.....etc. I can tell you people on this forum with equal 1500 trucks have much better results with the bigger engines offered. That's speaking of the big 3 domestic US made trucks. Randy
Old 11-11-2009, 05:34 PM   #3
bikendan's Avatar
tell the DH that you won't see much difference in gas mileage between the v-6 and the v-8.
it's a common myth that a v-6 gets much better mileage than a v-8, especially in truck/van categories.
he'll probably find only a couple miles per gallon better with the v-6.
get the v-8.
Old 11-11-2009, 06:28 PM   #4
I'm building my case : ).
Cheri
Old 11-11-2009, 07:04 PM   #5
TulsaSteve's Avatar
Try and get something with a factory integrated tow package that includes a transmission cooler.
Most likely that would only come on say... a.. V8...
TulsaSteve is offline   Reply With Quote
Old 11-11-2009, 09:30 PM   #6
bsmall's Avatar
V-8
Bill
2008 GMC Duramx-2500HD 4x4 CrewCab
52 Gallon Titan Fuel Tank
Reese18K Signature Series 5th Wheel Hitch With Slider #30085
2010 Wildcat 28RKBS (West Coast Model)
bsmall is offline   Reply With Quote
Old 11-12-2009, 05:25 PM   #7
to the point.
Cheri
Old 11-12-2009, 06:49 PM   #8
Yes, V-8 is the way to go with heavy duty tow package. As far as gas milage options are limited, with a gas engine 8 to 10 maybe 12 on flat ground. As far as dogs I towed with a 1997 GMC Suburban and had 3 Retired Greyhounds in the back. There weights were 78, 85 and 97 lbs and two kids, it worked for us.
Old 11-13-2009, 03:37 PM   #9
Since you have a trailer you will travel, When you travel you will come across hills, with names that have "Mountain" in them, then you will know that a V-8 was the right thing ot get,
Life is something to do when you've finished breakfast
Chuck & Margie
Both Retired
08 2500HD Silverado 6.6L Duramax
Flagstaff 829fkss
Round Mound of Sound is offline   Reply With Quote
Old 12-07-2009, 03:42 PM   #10
WDH/Sway
OK so the tow vehicle is in the works, Chevy Express Van 2500 4.6L V8
Now I need to purchase WDH and sway control. My trailer has a 500lb tongue weight but now has 2 batteries and 2 large propane tanks. What type WDH and sway do you recommend?
Cheri
