Old 04-25-2014, 10:33 AM   #151
davel1971's Avatar
Originally Posted by jimmac28 View Post
Actually the Ram rear suspension is much more than coil springs, its four link with a panhard bar. Its a very good suspension much better than a leaf springs.
You have to have 4 links with coil springs otherwise you would lose the axle. It doesn't make it better, it makes it not fall out
Sent from my SCH-I535 using Forest River Forums mobile app
David & Lynn
Old 04-25-2014, 12:40 PM   #152
No you can use a truck arm which is more common, four link/bar is the hot setup with a panhard bar and sway bar, is the best for a solid rear axel.
2014 Silverback 33RL
2013 F350 DRW 6.7
jimmac28 is offline   Reply With Quote
Old 04-25-2014, 12:50 PM   #153
4 link and a Jacobs ladder (Robert's Link) is best for a solid rear axle like a sprint car has.
Old 04-25-2014, 01:02 PM   #154
Ya but what about all that stager you'll have, all you can make is left turns.
2013 F350 DRW 6.7
Old 04-25-2014, 01:26 PM   #155
No stagger if you run the same size tires. BTW, who wants to turn right except to correct the slide?
The Jacobs ladder (Roberts Link) makes the frame work straight up and down where the panhard bar does not.
Old 04-25-2014, 07:30 PM   #156
SKnight's Avatar
And much more expensive to produce at a strength to control the rated weight. It's a truck, let it ride like a truck, that's why leaf springs have won over the years.
Customers finally won out, now they have a strong suspension that actually rides nice.
Old 04-26-2014, 04:28 AM   #157
Just a member
kandl's Avatar
Not exactly...
The General produced a line of trucks in the late 60s that incorporated coil springs with a three-link system. Two trailing arms mounted to the frame and connected to the axle and a track bar (panhard for the french connection types). The trucks actually handled quite well until something was dumped into the bed. The system did not work well loaded and the trucks wallowed badly. The coil sprung GM pickups disappeared in 1970.
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge 1500 (the Beast)
kandl is offline   Reply With Quote
Old 04-26-2014, 05:49 AM   #158
davel1971's Avatar
either way, you need a series of arms to hold the axle in place with coil springs and none of it has a place in a truck
David & Lynn
tow vehicle
