Old 07-21-2011, 07:24 PM   #11
M109Rrider's Avatar
use mine every chance I get.
Jason and Billie
2005 Dodge Ram 2500, 4X4, QC/SB 5.9L Cummins
15k non-sliding Hidden Hitch (they lied, it's not hidden at all)
2011 Prime Time Crusader 320RLT
M109Rrider is offline   Reply With Quote
Old 07-21-2011, 07:53 PM   #12
Lottery Non-Winner
Ovair's Avatar
Depends. I no longer have a pickup. But when I pulled using a Chevy 1500, the owners manual (at that time) said don't. Later when I had a 3500, the owners manual said it was fine (newer, bigger, diesel vs. gas). There are driving considerations that might preclude using cruise (rain, ice, heavy traffic, terrain), but I believe the biggest show stopper is if the vehicle was engineered to accommodate using cruise while towing. If your book says okay, I say okay.
2011 Georgetown 337
2009 HD FLHTCU
2007 HD FXSTC
Ovair is offline   Reply With Quote
Old 07-21-2011, 08:41 PM   #13
I always use the cruise. There is nothing more irritating, especially on the interstates, than someone who isn't using cruise and cannot maintain a constant speed.
As for the comment about safety, the lightest tap on the brake pedal disengages the cruise, and the brakes aren't even applied.
Old 07-21-2011, 09:04 PM   #14
Agreed!
And for safety, you can also hit the cruise's "off" button, or gently squeezing on the trailer brakes will typically shut the cruise off as well if you are in a sway situation.
2012 Flagstaff 8528 BHSS
2008 Ford F250 Crew Cab 4x4 6.4L Power Stroke
fordmantpw is offline   Reply With Quote
Old 07-21-2011, 09:54 PM   #15
Fire Instructor's Avatar
I use mine whenever I can.
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 07-22-2011, 08:04 AM   #16
maxwell18's Avatar
Thanks everyone, I was curious about the temp. mostly.
maxwell18 is offline   Reply With Quote
Old 07-22-2011, 08:23 AM   #17
I have always used mine. You would be hard pressed to be able to maintain speed manually compared to cruise.
If you couple it with ScanGauge you can really figure out where to operate cruise as well as monitor transmission temps if available.
Some of the newer vehicles are coming with cruise control that has a setting for towing. I wish mine had that.
While it is true that cruise has a bunch of problems in the mountains I have learned a few tricks. For one I step on the accelerator to start picking up speed early for the cruise system. When going the down the down side since the CC will lag considerably, I unlock the CC and hit resume. The engine gets back to where it should much quicker...
Foard County News & Sassy Schoolmarm
with Lady & Chloe, 2013 39 days, 2014 59 days
2017 GD Imagine 2800BH
'07 GMC Sierra 2500HD Diesel 4x4
Why I got into RVing & More Fun
ng2951 is offline   Reply With Quote
Old 07-22-2011, 08:30 AM   #18
M109Rrider's Avatar
Using cruise should have no effect on engine temp.
Jason and Billie
Old 07-22-2011, 08:32 AM   #19
M109Rrider's Avatar
Sometimes I'll disengage the cruise for a moment and coast to let the TC lock up and bring the RPM's back down if it seems like it's taking too long with the cruise on.
Jason and Billie
Old 07-22-2011, 11:52 AM   #20
Wanna Be Camper
SaskCampers's Avatar
I use the cruise all the time and put the tranny in tow/haul. The computer does a fine job and does not let it lug down.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
