Old 07-05-2016, 10:07 PM   #11
MT Biker's Avatar
I have a 2011 Ram 1500 2dr 2wd and with the WDH properly setup I don't have any sag issues (my tongue weight is a lot less than the OP)
When I was using the truck itself to haul PA equipment it used to sag and actually rest on the bump stops.
I took the truck while it was loaded to a spring shop and they took some weights and measurements to have a custom set of rear coil springs made up.
It cost about $700 total (installed) and when the truck was loaded with about 2300lbs in the bed it sat perfect as if it was empty.
Since I sold that company and now just use the truck for towing our trailer I had the factory springs put back in.
I noticed no difference in ride with the heavier custom springs installed, might be a option to look into for your issue.
https://www.facebook.com/westshorerailway/
2011 Ram 1500
2016 ML23FB
MT Biker is offline   Reply With Quote
Old 07-05-2016, 10:07 PM   #12
m2kamp's Avatar
Originally Posted by B_phillips View Post
M2 would that still be the case if the front was leveled?
There is nothing wrong with my hitch setup or the way the truck rides or tow. The problem is the truck itself sits to low I am trying to find out to raise it without a lift kit and still maintain the level rise I currently have.
Sounds like what I suggested would work great for you. My front is not leveled but I don't mind the forward rake.
Its as simple as installing new shocks.
You will likely have to reset your hitch as the suspension will be handling more load with the Monroe Load shocks.
2015 Wildwood 26TBSS Equalizer 4pt 10k
2018 Ram 1500 CC 5.7L 4x4 3.92 LSD
2017 Ram 1500 CC 3.6L 4x2 3.55
m2kamp is offline   Reply With Quote
Old 07-05-2016, 10:42 PM   #13
m2kamp's Avatar
There are aftermarket springs available.
Google Tuftruck springs for Ram.
They have a lot of different options, including variable rate if you are worried about a rough ride unloaded. Around $300
Old 07-06-2016, 12:46 PM   #14
You say everything is perfect, except that your chains drag.
Wrap a bungee cord around the hitch,chains,power cord, and break-away.
Will NOT inhibit any way they are supposed to work.
Keeps everything out of the way (even when you cross the tracks in Louisiana)
Also......make sure your tongue post is HIGHER than your torque bars. I have seen many with the post almost dragging.
2012 Ecoboost Screw, 3.31 (yes....really) rear end.
2016 Flagstaff 26FKWS, about 7500 loaded
Retired AF Mustang.....Picker always looking to jam.
Major Oz is offline   Reply With Quote
Old 07-06-2016, 02:22 PM   #15
I have to agree with Major Oz. Without pictures of your WDH with the TV and TT hooked, this is all speculation. If everything is level from front of the TV to the rear of the TT, there's not much else you can do without major expense in changing the suspension.
gfarmcafe is offline   Reply With Quote
Old 07-06-2016, 05:09 PM   #16
davel1971's Avatar
are your chains longer than they need to be? Check the length at full turn. Maybe you can shorten them a few links and solve your problem easily.
David & Lynn
Old 07-06-2016, 05:33 PM   #17
brad10281's Avatar
I think many of you are missing that the OP wants his truck raised a couple inches in general...at least that's what it sounds like. I have a 2" level up front and airbags in the rear on my GMC Sierra. The airbags are great and I'm glad I chose those over blocks in the rear. Just be sure to reconfigure your WDH once you make any mods.
Brad & Gail
2012 GMC Sierra 1500 SLE
2015 Shasta Flyte 255RS
brad10281 is offline   Reply With Quote
Old 07-06-2016, 06:02 PM   #18
davel1971's Avatar
what I'm taking from it, is that this idea of raising truck was started by chains dragging, and he's looking for reasons to justify it. Just fix the chains and leave the truck the way it is.
David & Lynn
Old 07-06-2016, 06:50 PM   #19
Usually Confused Member
emm-dee's Avatar
I don't see raising (or even lowering) the truck making any difference at all. If the combined units are level now then raising the rear of the truck means having to lower the ball position on the shank to keep the trailer level.
Since the chains and tongue jack are attached to the trailer the "problem" is not going to be solved.
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
emm-dee is online now   Reply With Quote
Old 07-06-2016, 07:02 PM   #20
W5CI's Avatar
some folks have to much time on their hands and or to much money, just put a twist in the chains and enjoy your trip.
Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2017 Days Camping 77
2018 Days Camping 3
W5CI is offline   Reply With Quote
tow vehicle
