Old 07-06-2016, 09:45 PM   #21
Twisting chains lowers the shear strength. It might not matter much on a light pop-up but a large unit could shear G43 grade chains that are twisted enough to shorten them. Use a small diameter wire tie two links together creating a loop to shorten chains. When needed wire will break, chains will function as normal. A slight twist in the chain does not affect strength you would be challenged to get a very long chain perfectly straight.
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
Nights camping in 2017: 20 nights
Miles traveled in 2017: 1,530
uhduh camping is offline   Reply With Quote
Old 07-06-2016, 09:53 PM   #22
BandJCarm's Avatar
Find a welder.
Remove some links.
FROG AR-0019-242
BandJCarm is online now   Reply With Quote
Old 07-06-2016, 10:12 PM   #23
Usually Confused Member
emm-dee's Avatar
Very interesting fact that I had never heard before. I assume a tie wrap could be used as an alternative the wire?
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
Old 07-08-2016, 06:04 PM   #24
m2kamp's Avatar
OP, let us know what solution you went with and how you like it. Thanks
2015 Wildwood 26TBSS Equalizer 4pt 10k
2018 Ram 1500 CC 5.7L 4x4 3.92 LSD
2017 Ram 1500 CC 3.6L 4x2 3.55
m2kamp is offline   Reply With Quote
tow vehicle
