Old 07-05-2016, 05:48 PM   #1
Tow vehicle set up
Hey guys I hope this finds you well, I am about to make a mod to my truck and I am wondering if any of you have had any experience. I'm sorry if this is posted elsewhere I looked but did not find.
Let me say first my truck tows my TT perfectly fine and has no trouble at all and I am under all my manufacturer weight ratings by a good margine. The one thing I do not like about my truck is the how low it rides and tows. At times my chains drag the ground and I would like to bring the entire vehicle up to gain a little more clearance but I am not looking to lift the vehicle. I would like to level the front and add either air bags or adjustable shocks to the rear. I do not want my truck to ride nose high when towing so to mitigate that I need some sort of assistance in the back. I am afraid if I add adjustable shocks it will still sag below the front end when towing my TT that weights 6300lbs dry. If I add air bags I believe I can level it out to the front but that doesn't provide any more clearance when not in tow. So I am at an impass I looked at trading for a 2500 Ram as I have a 1500 now but I'm not paying that much a month for a few extra inches when my truck tows just fine. I just don't like the height at which it tows. I feel like the truck is somewhat lower already any input would be greatly appreciated. I hope that makes sense to everyone.
The shop near me advises I put a leveling kit on the front and air bags in the rear. Please forgive any typos I am posting on my cell phone.
B_phillips is offline   Reply With Quote
Old 07-05-2016, 05:59 PM   #2
SeaDog's Avatar
Why not go to a WDH and set things to ride level?
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
SeaDog is online now   Reply With Quote
Old 07-05-2016, 06:21 PM   #3
Thank you for your reply and I am sorry I should have clarified that. I do have a WDH and it does ride level when it is in tow and everything works properly. However, while it is engaged is what I want to change I would like it to tow about an inch and half taller so my chains don't drag on uneven surfaces and my electric jack doesn't get ripped off. What I hope to accomplish is keep everything in line the way it is while raised slightly. My truck rides lower than practical for me at all times. At times my front end may scrape when getting somewhere off of the road. So I would like to raise the front end by leveling it but in doing so would cause the rear to sag while in tow so I need to mod the rear end and I am not sure the best way to do so be it air bags or adjustable shocks. After leveling the front I need the rear end to tow in line so I need to mitigate the slight sag. I hope that helps.
Old 07-05-2016, 08:07 PM   #4
PHS79's Avatar
I have the mods that you are talking about, but sounds like mine sits a fair amount higher. In my F150 I am running a 2.5" leveling kit, air bags in the rear and 325/60/18s (roughly 34" tall and 13.5" wide). My truck sits dead level with no air in the bags but as soon as I put even a couple hundred lbs in the bed the rear squats, and since I think the truck rides too soft I always run around 15 psi in the bags when empty.
For the average 3 day weekend camping with my truck loaded with wood, games, bikes, ect I run 30 psi in the bags. I inflate them before hooking up to the camper and hooking up the WDH. Once hooked up to our 3220BH Passport my setup is close to level, the rear is down only about 1/2" from the front.
TT-2013 Passport 3220BH
TV-2004 F150 FX4, not exactly stock...
nights camped:
with 2001 Kodiak K215: 2010-10, 2011-12
with 2012 Grey Wolf 26BH: 2012-19, 2013-24, 2014-11, 2015-6
with 2013 Passport: 2015-13, 2016-15 booked
PHS79 is offline   Reply With Quote
Old 07-05-2016, 08:14 PM   #5
davel1971's Avatar
tell us a little more about your truck and trailer
David & Lynn
Old 07-05-2016, 08:23 PM   #6
PH do you think if you had harder springs in the rear you would still sag? Adjustable shocks I believe can raise the rear end another 2 inches.
Davel I have a 2014 Ram 1500 Crew Cab 2WD. I could post a picture if it would help. This newer generation ram sits lower in general than my previous one did. My trailer is a 27ft and has a dry weight of 6200lbs and a hitch weight of around 825 lbs. The truck does fine I just need it to ride higher is all I want to accomplish. I am afraid if I don't add air bags and go with shocks the truck will ride nose up.
PH I am glad to hear the level kit doesn't effect your towing and even with a leveling kit I can't put those size tires on my truck
Old 07-05-2016, 08:40 PM   #7
davel1971's Avatar
those trucks do sit fairly low compared to others, and equipped with very soft springs and have a low payload rating.
David & Lynn
Old 07-05-2016, 08:59 PM   #8
Need more information and pictures if possible. The type of WDH and how it's set up might be part of the problem. The receiver shank holding the ball may need to be readjusted to level everything, but the truck height should not be an issue given the weight of the trailer.
gfarmcafe is offline   Reply With Quote
Old 07-05-2016, 09:28 PM   #9
m2kamp's Avatar
Easiest and incidentally cheapest/trouble free solution is a pair of Monroe Load Adjusting Shocks for the rear axle for under $100 shipped.
Setup in my sig below. About 900 lb tongue weight, 6300 lbs.
Even with the tongue dead dropped on the hitch, the rear end remains higher than the front with a slight forward rake. Rides just like stock too, but will raise the rear about an inch vs. stock unloaded.
Hope that helps.
2015 Wildwood 26TBSS Equalizer 4pt 10k
2018 Ram 1500 CC 5.7L 4x4 3.92 LSD
2017 Ram 1500 CC 3.6L 4x2 3.55
m2kamp is offline   Reply With Quote
Old 07-05-2016, 09:31 PM   #10
M2 would that still be the case if the front was leveled?
There is nothing wrong with my hitch setup or the way the truck rides or tow. The problem is the truck itself sits to low I am trying to find out to raise it without a lift kit and still maintain the level rise I currently have.
tow vehicle
