Old 10-01-2010, 07:22 AM   #1
Nights Camped in 2010 - 2
Tow vehicle shocks
All,
I am going to replace the rear shocks on my TV soon and was wondering what some if you have done and with what level of success as far as improvement in your tow and ride? Thanks,
George Kelly
2011 Rockwood Ultra Light 2604
Dodge RAM 1500 Larime 4x4, 5.7 HEMI
Nights Camped 2010 = 18
Nights Camped 2011 = 15
sailingsuppo46 is offline   Reply With Quote
Old 10-01-2010, 09:53 PM   #2
milzat's Avatar
BILSTEIN
milzat is offline   Reply With Quote
Old 10-01-2010, 10:06 PM   #3
Mr. Black's Avatar
RS9000s
Steve
1999 Ford Superduty F250 PSD CC SB 6spd 4x4.
B&W goosneck/companion hitch, Airlift 5000 airbags.
2006 Sierra F28 Rear Kitchen 5th Wheel, 31' = 10k pounds.
Nights camped in 09-14, 2010-23
Mr. Black is offline   Reply With Quote
Old 10-01-2010, 10:13 PM   #4
NWJeeper's Avatar
ARB (Old Man Emu) shocks are right up with Bilstein as the tops in my book. Nothing else compares. Don't know if they have shocks for the Dodge or not. I am not a fan of shocks with the rubber accordion covers that can trap moisture against the rod. OME uses a metal stone guard to protect the rod but let moisture out. Bilstein uses either a metal or plastic stone guard like OME I belive.
Ed & Wendy
www.nwjeepn.com
Old 10-01-2010, 11:02 PM   #5
Hi sailingsuppo46. I have an 06 Quad cab 1500 hemi, and I have Bilstein shocks. They had the front ones in stock, but I had to back order the rear ones. VERY happy with the much improved ride quality- towing and not towing! I also put Hellwig helper springs on my Ram- side to side sway was a problem with the soft 1500's ride. The biggest improvement for that issue was LT rated tires. MUCH stiffer sidewalls, minimal ride change with the shocks. Feels much safer towing. Now if I only had a steeper rear end gear! (currently 3:54 on 17's) Want a 3:73 or 3:91. My next truck mod, more than likely! Randy
Old 10-03-2010, 06:19 PM   #6
CampeRooo
rthrbelsewhere's Avatar
If you're replacing the stock shocks on your 1500, you're going to notice a difference no matter what brand you go with. I think the Bilstein is probably the most popular among all makes and models, however, last year I changed mine out for a complete set of Edlebrock's after chatting with a GMC 2500 diesel owner and his experience. I can't really tell you much more than that I am satisfied with my purchase with or without my trailer on the hitch. I can say that I do notice a big difference when hitting potholes or bumps in the road and I'm glad I finally changed them out. Good luck with your choice.
Where we've been:
2000 Rockwood Roo M-18 Hybrid
2006 Dodge Ram 2500 Auto 5.9 Diesel
Gone but not forgotten -1986 Rockwood 1003 PUP
rthrbelsewhere is offline   Reply With Quote
