Old 10-23-2010, 08:51 PM   #181
daverain's Avatar
Crossroads cruiser 30' tt 2005
02' ford excursion 3:73 gears v-10
about 7000 lbs.
Hensley hitch the best!
9 mpg
soon to be 2011 palomino sabre(forest river) 31 rlds
daverain is offline   Reply With Quote
Old 10-23-2010, 09:13 PM   #182
daverain's Avatar
Thumbs up Who tows in overdrive
Adding to the previous post on tow vehicles, mileage, and weight, wondering how many of us stay in overdrive and when do you switch it off? We have been using the same tow vehicle for 8 years mostly in od except for hills with no problem, change the trans oil every 20-25k with no strange particles in the pan, trans hunts a little on grades but I like the lower rpms in od. My excursion in od runs about 2100 rpms which seems to be the engines sweet spot. Has anyone cooked their trans running in OD?
Dave and Rainy
02 ford excursion v10 catback and chipped 3:73
05 crossroads 30 cruiser
hensley arrow
Old 10-24-2010, 07:56 AM   #183
Wanna Be Camper
SaskCampers's Avatar
The newer Dodges have tow/haul and o/d off. I always use tow/haul and if I am towing in a real hilly area go to O/D off as it cuts down on shifting. Mind you Hemi's love to rev so having it running it in the 3500 range is no biggy.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 10-24-2010, 08:31 AM   #184
Herk7769's Avatar
Speed Control On - Tow Haul On
With the Allison Tow/Haul mode it works best with speed control on (except on slippery roads - NEVER do this with speed control).
Up shifts and downshifts occur at the correct points to maintain speed. Due to the shift point at cruise, occasionally the final shift to 6th gear does not occur when I get to cruise speed (usually when its a 55 MPH highway) when we are on level road. When that happens I just click off the Tow/Haul, let it up-shift, and put it back on again. That seems to make the Allison happy and my tach shows a 300 RPM drop. Approaching a grade, the transmission will shift as necessary to maintain speed.
HAM CALLSIGN - KC3FFW
Old 10-24-2010, 11:58 AM   #185
Villa Estate 392FLFB
The_Stuff's Avatar
I used tow/haul mode for my trip home to. it holds rpm's higher to keep the power and down shifts to help braking.
One state/province at a time!
The_Stuff is offline   Reply With Quote
Old 11-11-2010, 07:40 AM   #186
34 ft. trailer, 7,800 lbs. loaded, Chevy Silverado 1500, 11 to 12 mpg @ 60 to 65 mph on level to slightly hilly roads and 8 to 10 mpg on steeper hills and mountains.
Happytrails2U2 is offline   Reply With Quote
Old 11-11-2010, 08:17 AM   #187
32ft Trailer approx 6000lbs loaded, 09 f150 screw, to early to post mileage, Valley WHD dual Vally sway control Prodogy P3 brake controller, speed hanging back
2009 F150 SCREW4x4 Prodigy P3 and tow package Valley WDH and dual anti sway
2006 Party Barge 21 90 Merc Optimax
2011 RockWood 2702 SS arrived 11.10.2010
nights camped 2010 6
threegr8katz is offline   Reply With Quote
Old 11-12-2010, 12:12 AM   #188
Retired FF
wrogers's Avatar
30 ft trailer approximately 7,000 lbs loaded. 2010 Ram 2500 CTD averaging 12 mpg when towing. No real hills yet, all Florida driving
2008 Salem LE 27RB -- 2010 Ram 2500 crew cab 6.7L Hummin Cummins
wrogers is offline   Reply With Quote
Old 11-12-2010, 07:46 AM   #189
32ft 5er, 12500Lbs, Dodge 1ton 6.7L Diesel Dually 4X4, towing MPG is 12MPG average. Use Tow Haul, depending on road use and speed, use 5th,6th or overdrive. Always use EB.
bailer6334 is offline   Reply With Quote
Old 11-12-2010, 08:09 AM   #190
34' 5er, 13,000 lbs., F-250 SD Crew Cab 4x4 6.0 Powerstroke (Banks 4" exhaust, intercooler, air box), towing MPG is 9-10MPG. Only use "tow haul" feature when going down hills for braking.
nailit is offline   Reply With Quote
