Old 10-11-2016, 10:39 AM   #11
Seachaser186's Avatar
They are 275/65R/18 116T
Seachaser186 is offline   Reply With Quote
Old 10-11-2016, 10:54 AM   #12
The load index is 2756; you would exceed GVWR way before the tire rating.
Old 10-11-2016, 12:04 PM   #13
Head Rambler
Now that we've sidetracked the OP's thread. I'm not sure they ever got a good answer.
Originally Posted by Ltynman View Post
Hi: My question is, should I increase the tire pressure in my truck when towing?
Norm
I personally would increase the pressure to the max sidewall pressure when towing. It makes the sidewall a little stiffer and therefore helps with sway.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 10-11-2016, 12:26 PM   #14
wmtire's Avatar
and have more load rating than some LT tires.
If only the tire manufacturers would make it so easy.
There's a thing called "derating" when using a Passenger tire on a pickup or trailer. This thread may help explain that.
New 10 ply tires help
To the OP's question, it would help to air up your tires to the max stated on the tire when using the trailer. However, knowing if that is too much or not enough, is really dependent on how much weight is on the tires, which can only be properly ascertained by weighing it on scales.
2011 Flagstaff 831 RLBSS
Materialism: buying things we donít need with money we donít have to impress people that donít matter.
Old 10-11-2016, 03:48 PM   #15
Tow Pressure
Agree!! go with MAX sidewall recommended pressure less a litle in the fornt. Worst case is a hard ride but without a blown tire. All things being equal!
pdqparalegal1 is offline   Reply With Quote
Old 10-11-2016, 04:25 PM   #16
Can somebody answer this question? If you inflate to max psi for towing the psi will increase when the tires heat up. Is the max psi for a cold tire?
Old 10-11-2016, 04:32 PM   #17
jftrombley's Avatar
Max pressure on the sidewall is cold. I towed a travel trailer with a Ford F150 and did raise the rear tire pressure to 50 PSI for my Bridgestone tires with a max of 55psi. If you have light truck tires that is what you do to prevent low pressure issue like rubbing the side wall.
jftrombley is offline   Reply With Quote
Old 10-11-2016, 04:41 PM   #18
The reason I asked the question, there are those who are saying to inflate to max psi for towing. If you drive the psi will exceed the max. That is why I don't inflate to max to allow room for expansion.
Old 10-11-2016, 07:51 PM   #19
The pressure rating on the tire is always specified cold. The tire company takes the expansion into account. I've often wondered when it is 120 degrees in Phoenix if they really took all of the expansion into account. The General Services Administration supplies the Forest Service with Passenger tires on all of the pickups it sells us. They don't hold up like Light Truck tires. I had two flats the same day multiple times. You'll find that LT tires are more stable and last better, but they definitely ride rougher.
mnoland30 is offline   Reply With Quote
Old 10-11-2016, 08:36 PM   #20
Chuckinca's Avatar
The door plate on my Ram 3500 states max rear tire pressure when loaded is 75 PSI and 45 PSI with light load.
What is the major advantage in running the rear tires at a much lower pressure?
2011 Rockwood Windjammer 2102W
2008 Ram Laramie 3500 Megacab 4x4 Cummins 6.7L Turbo Diesel
(the near max loaded 2006 F150 5.4L V8 would only go 55 MPH Westbound on I-80 in Wyoming . . . not good when semi's are passing you at 80 MPH)
Chuckinca is offline   Reply With Quote
pressure, tire, tow vehicle
