Old 07-31-2014, 07:18 AM   #21
I have LT tires with LR E and run loaded 65 rear/60 front. Unloaded 45/45. gives a better ride when I lower it unloaded, and pull MUCH better loaded at the increased pressure.
Skippy38 is offline   Reply With Quote
Old 07-31-2014, 07:20 AM   #22
I was running 65/80 and recently dropped to 50/50. It made a big difference in ride quality. I see no need for an empty truck to have that much air pressure. I will be going back up when towing.
comfun1 is offline   Reply With Quote
Old 07-31-2014, 07:36 AM   #23
textman's Avatar
Run 75 in the front and 60 in the back four.
2012 Cedar Creek 36B4
2007 Ford F-350 Dually Crew Cab 6.0 Studded w/EGR Delete
Loving Life
textman is offline   Reply With Quote
Old 07-31-2014, 10:49 AM   #24
Resident Masshole
force's Avatar
Some interesting advice here. I may need to reconsider the rear tires. My 3/4 ton is bouncy as heck unloaded (I don't have to commute anywhere so a large portion of my driving is on secondary roads). Will have to experiment at 60 or even 50 psi to see how much it improves.
Tom F.
2013 GMC 2500HD SLT Crew Cab
2013 Rockwood Roo 23SS
Nights camped in 2014: 8
Nights camped in 2013: 30
force is offline   Reply With Quote
Old 07-31-2014, 11:07 AM   #25
TheUO's Avatar
I'm no expert, but I can take a stab at it and pass along advise I've received.
Just put new LTs on the truck yesterday since we are taking a cross country trip in a few weeks and the rears were getting a bit old and worn.
The "tire expert" at discount I was shooting the breeze with basically told me when under load to run them at basically their max since they hold the most weight when they are full.
The 2500's door sticker calls for 65 in the front and 80 in the rear which is what I keep her at all the time. Is the ride a bit rough at times? Sure, especially when unloaded.
Tires with less pressure have more contact area with the road and provide better grip, but more rolling resistance which reduces mileage. Theoretically, at least.
Since the bed is pretty light just by itself, reduced pressure when unloaded isn't necessarily a bad thing as you may want that grip and better ride at the cost of a bit of fuel. My truck is basically a work horse though and when she's out and about she's usually hauling something so I keep her at 80 in the rear all the time.
Since the front isn't really affected much when towing (other than maybe lifting a bit when the trailer bears down) I find that keeping the front at the recommended 65 is just fine.
If I had any advise, it's to increase the pressure before loading up. What you do unloaded is all personal preference, unless you run way to low pressure all the time then you're contributing to premature wall failure and such.
Again, I'm not a tire guy and most of this is basically hear-say. Feel free to correct anything that's incorrect or misleading, won't hurt my feelings.
TheUO is offline   Reply With Quote
Old 07-31-2014, 11:08 AM   #26
Camper Less Camping
Cajun Po-Boy's Avatar
I have Load Range E tires that spec 80psi max cold...unloaded, I run 65psi in all fours - nice ride...When towing, I'll air up rear to 78psi as I have a pin weight just under 2500lbs and it rides great with that setup (rear airbags set at 40psi also).
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 07-31-2014, 12:29 PM   #27
Smitty72's Avatar
hhhmmm.... door says 43 PSI all around. Probably just for casual driving. I am gonna try 45 - 55 maybe, just to be original. Will definitly add more before tow time.
Smitty72 is offline   Reply With Quote
Old 08-02-2014, 08:03 AM   #28
Smitty72's Avatar
Update - just burnt out my cheap air compressor. Do you guys usually go to service station or carry your own. For those of you that have your own what kind of compressor do you have? What kind of price should I look at paying for one that will do the job?
Old 08-02-2014, 08:17 AM   #29
Wanna Be Camper
SaskCampers's Avatar
First for all you guys who put LRE tires on your 1/2 tons and run them at 60 to 80 lbs when towing, I sure hope you had high pressure valve stems installed as the factory ones on a half ton are probably only rated to 50 psi and that you have checked to ensure your rims themselves are rated for those pressures. Another thing an equivalent LT tire must be run at a higher PSI to have the same load carrying capacity as the P Metric you replaced.
In this link go down to page 71 and have a read.
http://www.toyotires.ca/sites/default/files/loadinflationtable.pdf
I used to run LRE tires on my 04 Dodge 1500 but only ran them to a max of 45psi. I also run what the sticker on the door says in the case of my F250 it is 65 all around for a 9600lb GVWR truck. My old Dodge 2500 was 65F/70R for an 8800lb GVWR go figure although the Ford tires are rated for 500 lbs more max weight than the Dodge ones were so that is probably the deciding factor.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 08-02-2014, 08:24 AM   #30
Wanna Be Camper
Get one of these for home, when they go on sale you can get them for about 100 bux. They are a great little compressor and can be used with some air tools like nailers etc as well. I only go to a gas station if I am on the road.
Mastercraft 5 Gallon Compressor | Canadian Tire
John & Deb
pressure, tire, tow vehicle
