Old 07-30-2014, 07:37 PM   #1
Smitty72's Avatar
Tow Vehicle Tire Pressure
I was wondering what most of you run your TV tire pressure at? I currently have Goodyear LT tires that have a max PSI of 80 but am currently running around 40. Should I add more tire pressure when I am under load especially when towing my TT and all loaded up with bikes, camping gear, firewood and whatever else I can throw back there? Thanks for your thoughts.
Smitty72 is offline   Reply With Quote
Old 07-30-2014, 07:42 PM   #2
SYE
SYE's Avatar
Mine are rated at 80 as well, when I am not towing, I run them at 50.
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 59, 2020 0,
2021 4 reserved
SYE is offline   Reply With Quote
Old 07-30-2014, 07:43 PM   #3
LR E tires, loaded 60 front, 65 rear. Unloaded 35 front, 30 rear.
Old 07-30-2014, 07:46 PM   #4
Smitty72's Avatar
So you guys have been adding pressure when preparing for a trip... I assume do this before you start while tires are cool?
Old 07-30-2014, 07:53 PM   #5
Yes.
Old 07-30-2014, 08:03 PM   #6
Smitty72's Avatar
Thanks... I appreciate the info and will do the same for my next trip.
Old 07-30-2014, 08:18 PM   #7
schrederman's Avatar
My truck shows 80 psi - rear, and 65 psi - front. Max tire pressure (sidewall) shows 80 psi. That's what's in them... Not sure why you would run half that. Seems low...
J & D in Lovely Weatherford, TX
2016 Jayco White Hawk 28DSBH TT
2014 Ram 2500 Crew Cab 4X4 6.7L Cummins
schrederman is offline   Reply With Quote
Old 07-30-2014, 08:29 PM   #8
Smitty72's Avatar
I thought so too. But, that's what my tires were coming from the dealer? So I just assumed it was OK. It seems from previous posts here though that some people do run at a lower pressure when not under load. I would suspect it would be for better ride quality... and possibly proper performance depending on the utility/job we are using our vehicles for at the time. I guess?? Maybe??
Old 07-30-2014, 08:34 PM   #9
Resident Masshole
force's Avatar
I run what it says on the door sticker, 60 front, 70 rear (tires are rated for 80), regardless of towing or not. Don't see a reason to over-complicate things, or worse, take off and forget you are 20 psi short.
Tom F.
2013 GMC 2500HD SLT Crew Cab
2013 Rockwood Roo 23SS
Nights camped in 2014: 8
Nights camped in 2013: 30
force is offline   Reply With Quote
Old 07-30-2014, 08:41 PM   #10
Smitty72's Avatar
Well if there is any chance of forgetting I will ... I can see your point of setting it then forgetting it.
Old 07-30-2014, 08:52 PM   #11
Even with my advanced stages of CRS, I haven't forgotten yet.
Old 07-30-2014, 09:04 PM   #12
Smitty72's Avatar
lol... I had to look that one up My Dad says he suffers from CRAFT ... It must run in the family. ( can't remember a #%^ thing)
Old 07-30-2014, 09:16 PM   #13
dcheatwood's Avatar
My TV has E tires. I run 55 f&r unloaded, and 70 front, 75 rear when towing fiver.
2018 Forester 3011 DS
Old 07-30-2014, 09:25 PM   #14
I don't forget it... I check them monthly... Fuel economy is more affected by low tires than most other things. I'm cheap... but at least I know it.
Old 07-30-2014, 09:29 PM   #15
turnerpa's Avatar
I also have load range E tires and I run 65 in the front and 80 in the rear at all times. I do this because there have been many times when I get somewhere and all of a sudden I have to hook onto some sort of trailer or end up loading the bed with stuff. I figure if I just leave the rear at 80 I'll never have to worry about what pressure I have for the load that's on me.
turnerpa is offline   Reply With Quote
Old 07-31-2014, 04:53 AM   #16
Tire pressure advice is all about load on the seperate tires, but mostly axle loads are used.
I determined by reactions that if you have 85% of the load, that the pressure is calculated for, in real on a tire , that below that discomfort begins by bouncing.
for trailers I dare to go as low as 80% before screws tremble out of the woodwork.
Then front axle does not chanche much unloaded or loaded , because you simply cant put many things in the cabine, exceptions , verry heavy persons and motor on the front bumper.
Even the weight of the luggage is mostly even behind the rear axle wich lifts up the front.
So if we calculate the pressure for the GAWR ( give alternative word reading, correction Gross axle weight rating) +5% the minimum weight if equally devided ( never so) can go as low as 85% of 105%=89,25% , comfort is still acceptable. Example GAWR front 4000 lbs then if real axle weight is 3600 lbs comfort is still ok.
Rear is another thing , loaded and unloaded makes a big difference.
Though you are not allowed to go over the GAWR motorhomes do often go over that , but normal lighttrucks , wich is the case here, stay under that too.
So for rear you have to use different pressures unloaded and loaded because it cant be done with one pressure to keep the loadpercentage ( as I call it L%) between the borders of 85% and 100%.
Because driver and co driver are in front, the rear bumping is not noticed that bad. So I would calculate pressure ( with my spreadsheet for motorhomes) for GAWR/0.85 to give no bumping when excact GAWR and leaves as much possible reserve for little overloading ( 18%).
Its never bad for the tires to keep at 80 psi ,only for your comfort but also important gripp.
To make this F( for ferry) long story short, let me calculate so give maximum load of tires and GAWR's . Dangerous quess of mine is front unloaded front 50 and rear 60, and loaded front still 50 and rear 80.
But if calculation gives 90 that is allowed by the tire-makers , because this 80 AT-pressure is not the maximum pressure of the tire, as is thought by many.
For SL ( standard load) /P-tires this maxloadpressure is 35 psi for american tires, and XL/reinforced/Extraload 41 psi . Those tires only give maximum pressure on tire between 44 and 60 psi . From C-load and up ( C-load 50 psi) they give the AT-pressure/maxloadpressure/reference-pressure on sidewall and the maximum pressure shal be about 1.4 times the Pr ( wissle sound oh no Pressure reference), I concluded of a PDF of Semperit( Continental).
jadatis is offline   Reply With Quote
Old 07-31-2014, 05:28 AM   #17
BiigDaddy's Avatar
X2
2013 GMC Savana 2500 FBI Edition
2015 Rockwood 8327SS stuffed with 5 kids!
SE Michigan
Nights camped 2014: 48
BiigDaddy is offline   Reply With Quote
Old 07-31-2014, 06:23 AM   #18
Smitty72's Avatar
Well it seems like I am currently running low unloaded already and will certainly be adding more PSI in the back next time I hitch up. I guess it will be a little trial and error as far as keeping the comfortable ride vs optimal performance. Although it is my daily driver it doesn't go too far, just around town, when not towing. Thanks for your help.
Old 07-31-2014, 06:33 AM   #19
camper1999's Avatar
65 front 75 rear that what is list in my manual and on the door.
2011 GMC 2500HD Diesel
Old 07-31-2014, 06:39 AM   #20
X2
036.6turbo is offline   Reply With Quote
pressure, tire, tow vehicle
