Old 07-30-2014, 07:37 PM   #1
Smitty72's Avatar
Tow Vehicle Tire Pressure
I was wondering what most of you run your TV tire pressure at? I currently have Goodyear LT tires that have a max PSI of 80 but am currently running around 40. Should I add more tire pressure when I am under load especially when towing my TT and all loaded up with bikes, camping gear, firewood and whatever else I can throw back there? Thanks for your thoughts.
Smitty72 is offline   Reply With Quote
Old 07-30-2014, 07:42 PM   #2
SYE
SYE's Avatar
Mine are rated at 80 as well, when I am not towing, I run them at 50.
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 12 Nights Camped 2018 57 nights reserved
SYE is offline   Reply With Quote
Old 07-30-2014, 07:43 PM   #3
LR E tires, loaded 60 front, 65 rear. Unloaded 35 front, 30 rear.
Old 07-30-2014, 07:46 PM   #4
Smitty72's Avatar
So you guys have been adding pressure when preparing for a trip... I assume do this before you start while tires are cool?
Old 07-30-2014, 07:53 PM   #5
Yes.
Old 07-30-2014, 08:03 PM   #6
Smitty72's Avatar
Thanks... I appreciate the info and will do the same for my next trip.
Old 07-30-2014, 08:18 PM   #7
schrederman's Avatar
My truck shows 80 psi - rear, and 65 psi - front. Max tire pressure (sidewall) shows 80 psi. That's what's in them... Not sure why you would run half that. Seems low...
J & D in Lovely Weatherford, TX
2016 Jayco White Hawk 28DSBH TT
2014 Ram 2500 Crew Cab 4X4 6.7L Cummins
schrederman is offline   Reply With Quote
Old 07-30-2014, 08:29 PM   #8
Smitty72's Avatar
I thought so too. But, that's what my tires were coming from the dealer? So I just assumed it was OK. It seems from previous posts here though that some people do run at a lower pressure when not under load. I would suspect it would be for better ride quality... and possibly proper performance depending on the utility/job we are using our vehicles for at the time. I guess?? Maybe??
Old 07-30-2014, 08:34 PM   #9
Resident Masshole
force's Avatar
I run what it says on the door sticker, 60 front, 70 rear (tires are rated for 80), regardless of towing or not. Don't see a reason to over-complicate things, or worse, take off and forget you are 20 psi short.
Tom F.
2013 GMC 2500HD SLT Crew Cab
2013 Rockwood Roo 23SS
Nights camped in 2014: 8
Nights camped in 2013: 30
force is offline   Reply With Quote
Old 07-30-2014, 08:41 PM   #10
Smitty72's Avatar
Well if there is any chance of forgetting I will ... I can see your point of setting it then forgetting it.
pressure, tire, tow vehicle
