07-27-2019, 06:41 PM
Tow vehicles
Simple question: can I expect a half ton pickup to be a better trailer puller than my 2011 6.2 Yukon Denali? We're presently pulling a 23 foot 6000# Rockwood (and struggling up the mountains). I'm asking because all the 1/2 tons I've looked at have smaller and less powerful motors than our Denali,
John
07-27-2019, 06:50 PM
Depends on the engine, hp, torgue, cargo capacities, tow capabilities. They have diesel half-tons with high torgue but low cargo limits. V8 engines with high hp and decent torgue but lacking in payload. Even v6 gassers with turbos and high torgue and high payloads. It's a nightmare trying to figure it out but you're doing your research and that's good.
Might help to know your SUV's hp, torgue, towing capacity and payload. Then others can chime in with experience and accurate references. Happy rv-ing.
2018 Forester 3011 DS
07-27-2019, 06:57 PM
John
The F150 3.5 Ecoboost v-6 is equal or superior to your 6.2 v-8 for towing power and torque.
07-27-2019, 07:42 PM
What's killing you in your 6.2 Denali is probably you gear ratio.
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Illegitimum non carborundum
07-27-2019, 08:03 PM
John
Are you sure you Are pulling 6000#s? What about gear and passengers fully loaded? Is is possible the issue is towing a larger load than a 1/2 is capable of? The 6.2 should have no trouble with 6000#s, unless it is not geared to tow.
TV - 2020 RAM 3500 Mega Cab SRW with 6.7 Cummins HO & Aisin 6 spd, 4k payload, 23k towing
2002 GMC Yukon XL 2500, 8.1 liter (496ci), 4L85e & positraction with 3.73 gears
TT - 2013 Dutchmen Aspen Trail 3130 QBS
Great bourbon-just about any of San Diego’s craft beer
07-27-2019, 09:27 PM
Hi dcheatwood,
Our Denali has a 6.2 L vortec V8, 403 hp @5700 rpm, 417 ftlbs torgue @ 4300 rpm. Gross weight of the vehicle is 3314#, and has a 3.42 rear axle, and has a heavy duty trailer package.
07-27-2019, 09:28 PM
Almost forgot, 8100# towing capacity.
07-27-2019, 09:49 PM
Tow vehicles
X2
And right as I said that I saw you posted specs.
So are we talking high altitude, maybe a 8% grade, is it in second or third gear?
Just glad to get away
07-27-2019, 10:58 PM
In my opinion most of it is your gearing. The 3:42 is for mpg not towing. I also noticed you said 403 hp at 5700 rpm, but how much horsepower around your normal driving rpms. I think most any newer truck with the new 8-10 speed transmission and at least 3:55 gearing would be better
2022 Chevy 3500 Diesel SWD
2022 Columbus 329 DVC
07-28-2019, 12:21 PM
Grammar Pedant
Also, that weight cannot be correct. A Yukon Denali will weigh a ton more than 3,300 lbs ... literally ... as in, you're at least 2,000 lbs too low on that weight.
Heavy SUV with low numeric gears aren't helping you. If you're at altitude, you're leaving a huge chunk of your power numbers at the bottom of the mountain (3% per 1,000'). A turbo/supercharged engine will help a lot.
On the face of it, a 6,000 lb trailer shouldn't be a big problem for a 6.2L, though. However, a modern F-150 3.5L EB with tow package (3.73 gears) would be a completely different experience towing that 6,000 lb trailer.
Former RV: 2018 Rockwood Mini Lite 2504S
07-28-2019, 12:26 PM
What you are calling Gross Weight is probably one axle. Total of Yukon is closer to 7,000 lbs than it is to 3,314 lbs.
FROG AR-0019-242
07-28-2019, 06:59 PM
That all looks good. Now to figure out how much weight it can carry. (payload/cargo capacity) That was the biggest limiting factor on my 1/2 ton.
07-29-2019, 12:02 PM
Had the same setup in an Escalade towing 7500. The 6.2 in the trucks usually has the same 3.42 ratio, but some shipped with 3.73's.
If you are pulling in the mountains, expect to run 3rd or even 2nd gear depending on the situation. The 6.2 doesn't mind revving, just keep an eye coolant temp.
2016 26RR and a 2018 OR371MBH
