Old 02-15-2015, 03:37 PM   #1
hockey11's Avatar
Towing 5th wheel with f150 ecoboost supercrew 5.5ft box?
We found a 22 ft light weight 5th wheel, all payload and tow ratings are good. Need to know if we can turn, back in and handle sharp turns without trailer and cab colliding? Anyone have this set up?
Sharon & Jim, Dutchess
Windjammer 2102w
Ford f150 4x4 EB 2014
2012 30, 2013 25, 2014 29, 2015 37
hockey11 is offline   Reply With Quote
Old 02-15-2015, 03:42 PM   #2
Blog: RVroadtripper.com
hbillsmith's Avatar
Check out the YouTube for the Andersen Ultimate fifth wheel hitch. Its for short beds and because it weighs the least it will save you about 100# of payload deduction. Of course for your case the trailers front nose design is very relevant. If its cut back like an Open Range or a Wildcat, you might be OK in A 5.5.
Maxxis 235/80/16E; AirBags w/AirLift 1 wireless compr; 4-Fold Tonneau; 6000# Dexters; mor/Ryde Rubber Pinbox & CRE3000 w/HD Wetbolts; Andersen UltimateII Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball; LCI Ground Control3 4pt+2pt Elec.Rear stabilizers; 3 Slidecovers; King Dishtailgater; 10ft. Portabote w/5hp Outboard; Dual A/C; Furrion48 Rearcam; Champion 3100 Inverter w/DIY Extended Run
hbillsmith is offline   Reply With Quote
Old 02-16-2015, 11:23 AM   #3
LTnTN's Avatar
The Reese Revolution or Sidewinder hitch gives you the setback you need too.
LTnTN is offline   Reply With Quote
Old 02-16-2015, 12:26 PM   #4
B and B's Avatar
Revolution allows 90 degree turns. I have had mine there just once to see, not advises as it does place a lot of stress on the wheels.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
B and B is online now   Reply With Quote
Old 02-16-2015, 12:38 PM   #5
jlbreaux's Avatar
I have a short wheel base and I installed the 5th airborne Sidewinder by Reese. It is a pain to hitch and unhitch but it is worth its weight in gold!
2011 Puma Unleashed 365 QLB
2006 GMC HD Sierra SLT quad cab 4x4 6.6L LBZ Allison tranny
2008 Arctic Cat Prowler 650 H1
2006 Polaris H.O. 500EFI Sportsman
1996 Harley Davidson Heritage Softail
jlbreaux is offline   Reply With Quote
Old 02-17-2015, 02:45 PM   #6
Send a message via Skype™ to stillontheroad
We tow a Rockwood ultra lite signture 8280 with F150 (2013) v8 with 6.5 foot box with no problems regarding hitting. The rockwoods do have "Cobra" extended hitch that helps. I believe tht you will need to install an extended 5th wheel hitch to totally void any hits. Do not let any dealer convince you to install the hitch in the truck further back in the box. That would solve the problem but your tow would be a nightmare and dangerous.
stillontheroad is offline   Reply With Quote
Old 02-17-2015, 02:50 PM   #7
Scootdawg's Avatar
I have a F150 and an 8289 5th wheel, I have the Reese on it and didn't have any issues at all:
2014 F-150 SuperCrew
2015 Rockwood 8289WS Diamond
Scootdawg is offline   Reply With Quote
Old 02-17-2015, 03:14 PM   #8
Jestercyco's Avatar
I run the pull right unit and can do 90 degree turns and have the short bed. I do run the morryde pin box.
Jester
2012 Super Crew 4WD 6.7 PSD
2015 Cardinal 3800 FL
2007 Road King Black Cherry-Hers
2007 Road King Blue-Mine
1979 FXS Hot Rod Shovelhead
Jestercyco is offline   Reply With Quote
Old 02-28-2015, 03:27 PM   #9
hockey11's Avatar
Thanks for the info. We decide to stay with the TT until we can afford a different truck!!
Windjammer 2102w
5th wheel, ecoboost, f150, towing, wheel
