Old 12-18-2015, 05:08 PM   #21
mike.t's Avatar
I have nothing against 1/2 ton TVs. I prefer 3/4 1 tons. I have never towed with a 1/2 so I guess I should just read and keep quiet on that subject. I had a 06' f-250 5.4 gasser that would sound like a screaming nightmare pulling a TT up a couple hills out side of Mammoth Ca. That's when I went to a diesel. Like you a much better towing experience.
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 12-18-2015, 06:28 PM   #22
drittal's Avatar
Another thing to keep in miND when towing with a 1/2 ton is frontal area limits. F150 has 60sqft limit in their towing guide.
drittal is online now   Reply With Quote
Old 12-19-2015, 06:19 AM   #23
Originally Posted by transamz9 View Post
Your husband does know there are a lot of "1/2 ton" trucks that have more "available payload" than a lot of "3/4 ton" trucks according to the little sticker right?
if you believe that I have some land for sale !
azwiz is offline   Reply With Quote
Old 12-19-2015, 07:42 AM   #24
transamz9's Avatar
My 2005 2500 sticker says 1,6xx# on the little sticker. I have some F150's at work with 2,3xx# stickers. So........ Where's the land?
transamz9 is offline   Reply With Quote
Old 12-19-2015, 09:10 AM   #25
CWSWine's Avatar
I have never seen one on 3/4 ton at 1600 payload. I had Chevy 2500HD Diesel LTZ loaded to the gills and still had 2475. You can check the F150 website there are a lot F150 with higher payload than my 2500HD but on the lots I have not seen a F150 over about 2000.
What additional equipment do you think was installed at your 2500 that added 875 lbs to the weight of the truck over my loaded LTZ? What was the trucks GVWR?
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 12-19-2015, 11:36 AM   #26
drittal's Avatar
2005 Dodge Ram 2500 with Cummins had 9,000lb GVWR. A base model QC 4x4 SB could tip the scales at over 7,000. A few options and a payload under 1700 isn't far fetched.
Old 12-19-2015, 11:44 AM   #27
CWSWine's Avatar
OK, that make sense with trucks GVWR of 9,000. If my 2500hd i use to own had with 2475 CC would only have 1475 CC with GVWR of 9,000.
Old 12-19-2015, 12:16 PM   #28
Retired
RubyDually's Avatar
Last truck was a 2010 chevy LTZ 2500HD Duramax with a GVWR 9200. Tare weight was 7200 plus the hitch and stuff...
2014 Chevrolet Silverado 3500 LTZ CCLB DRW D/A - Rancher Grille Guard - Transfer flow 40 gallon Toolbox/Tank Combo - Line X - Edge Insight
2015 Palomino Sabre 33CKTS - Platinum Edition - Progressive Industries EMS HW50C - JT Strong Arm Stabilizers - Ground Control 3.0 - 320 Watt Solar with 2000 Watt Inverter
RubyDually is offline   Reply With Quote
Old 12-19-2015, 01:02 PM   #29
drittal's Avatar
the new crew cab 4x4 diesel Ram 2500 have payloads around 2200-2400lbs.
Old 12-19-2015, 01:15 PM   #30
Kenny kustom's Avatar
Yup.
My 14 2500 CCSB CUMMINS on the cat scale was 7919. Gvwr ok 10k.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
I am nice!
2017 Dynamax Isata 4
