Old 06-06-2014, 10:02 PM   #1
Towing
We have a F.R. S. H. 272BH 6300llbs dry. Currently tow with a 2005 Dodge Hemi Quad and family does not fit. Looking at a used 2005 Cadillac Escilade which shows tow rating around 7800lbs. Any thoughts
Indycamper is offline   Reply With Quote
Old 06-06-2014, 10:20 PM   #2
Twisty's Avatar
Make sure you have enough payload. The tongue weight, passengers and cargo in the TV all have to be accounted for.
My F150 had a payload of over 1500 lbs and was rated to tow 7700 lbs. I ran outside the numbers more than once with 2 adults, 2 dogs, bikes, cooler, wood, etc.
You can't get big payload numbers in cars or suv's.
That is where the HD and SD trucks come in.
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
Twisty is offline   Reply With Quote
Old 06-06-2014, 10:31 PM   #3
Thanks, we have plenty of payload to account for. I do use a weight distribution system and sway bar. Money is tight and what we really need is out of reach now. Thanks for the reply.
Old 06-06-2014, 11:02 PM   #4
Twisty's Avatar
All I ask is that you check the numbers friend.
2012 Surveyor SV264
NW Oregon
Old 06-07-2014, 02:16 AM   #5
bikendan's Avatar
first, you need to post better specs/numbers.
is the trailer's 6300 number the website/brochure "dry" number or the actual UVW sticker weight from the factory?
need more info on the Caddy: engine size, payload amount, rear end ratio and so on. where did you get the 7800 number?
rarely does a 1/2 ton vehicle like the Escalade, have lots of payload.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 06-07-2014, 02:55 AM   #6
Just a member
kandl's Avatar
Originally Posted by Indycamper View Post
Looking at a used 2005 Cadillac Escalade which shows tow rating around 7800lbs. Any thoughts
You could probably find a 2005ish, gas-powered, 2500 crew for less than what the Escalade is worth. Something like a Dodge Mega-Cab?
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge Ram 1500 CC 4x4 (ya.. it's got a Hemi
kandl is offline   Reply With Quote
Old 06-07-2014, 05:55 AM   #7
davel1971's Avatar
SUVs typically have WAY lower payload capacities than pick ups because of the extra weight of the vehicle body. Tow capacity is usually quite a bit lower too. Escalade will be worse than most others because the weight of all that bling takes away from payload. Maybe look at a Suburban or Excursion
David & Lynn
Old 06-07-2014, 06:41 AM   #8
prof_fate's Avatar
UNless it's a 2500 class TV you'll be way over in payload and GCWR i'm thinking.
Remember - it can tow 7500lbs with NOTHING in the TV. Every lb you add to the TV you remove from the tow rating (because of GCWR).
A suburban 2500 is what you should be looking at and check the numbers.
Chris, Wills (16) Evie (13) & Toby our collie (6)
2011 Grey Wolf 28BH
2013 Chevy K1500 Crew w/ Reese StraitLine Dual Cam
Nights camped 2011: 11 2012: 18 2013: 12 2014: 12 2015: 13 2016: 56 2017: 8+
prof_fate is offline   Reply With Quote
towing
