Old 12-05-2015, 12:08 AM   #61
Canadian Contingent
Dogpatch's Avatar
I'll admit it. I'm overweight.
Oh.....I just noticed we're talking about towing and not physical prowess. LOL
(A little light hearted humor)
Les and Bonnie with 4 Leggers Bella and Shelby
2010 Cardinal 3450RL 4 slide Full Body Paint pushing our 2015 Ram 3500 Laramie 4x4 CCSB SRW - Pullrite 2900 Superglide 18k
Dogpatch is offline   Reply With Quote
Old 12-05-2015, 01:17 AM   #62
Fulltime family RVer
Originally Posted by doc73 View Post
I think a few have said that ALL trucks over 5 tons GCWR need to stop in the MD weigh stations according to the state. They do not seem to enforce though.
GVWR - truck alone. I'm over and supposed to stop. But as mentioned- it is NOT enforced. And, I don't stop.
ependydad is online now   Reply With Quote
Old 12-05-2015, 01:34 AM   #63
You would still need to technically stop, your over 5 tons. I think ependydad is the one who found the final ruling from the state. For the record, I've never stopped.
Sent from my SAMSUNG-SM-G870A using Tapatalk
I've said it before and I'll say it again, you do not have to stop unless you're hauling that RV commercially, it is not enforced because you do not have a dot number and company name on your pickups, these weigh stations are for anything with a dot number on it, you will never be bothered by them, but throw a number on your door and they will chase you down
jerky is offline   Reply With Quote
Old 12-05-2015, 04:21 AM   #64
Usually Confused Member
emm-dee's Avatar
Now that I think back to the time I got pulled into a "checkpoint" (which just happened to be located at a weight station) I asked the inspector if I'm supposed to stop. Response was no unless they were doing the occasional safety check. In that case the RV would be notified (via flashing blue lights) of the need to stop.
If you're hauling horses into Florida you're supposed to stop at the first point for a check of proper health paperwork for the animals. They also do a "safety" check but don't bother to look at weights.
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
Old 12-05-2015, 08:03 AM   #65
Who Dares, Wins
doc73's Avatar
Thanks, could not remember if it was combination or weight. I remember you putting the leg work in to get the final answer from the MD dot.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 12-05-2015, 08:15 AM   #66
Ambassador
Ken K.'s Avatar
This seems like a silly question, something similar to how many of you walk around with loaded shotguns to your head.. if you do either you had better be walking on egg shells.
2016 Ford F250 Crew Cab 6.2 L w/Ride Rite Air Leveling System.
2017 Rockwood Signature Ultra Lite 8335BSS
Ken K. is offline   Reply With Quote
Old 12-05-2015, 08:37 AM   #67
transamz9's Avatar
Not no where near the same thing.
transamz9 is offline   Reply With Quote
Old 12-05-2015, 09:05 AM   #68
Oaklevel's Avatar
Not even close to apples & oranges in comparison...... more like apples to redwood trees....... Not at all the same............
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 12-05-2015, 09:15 AM   #69
I am right at 80% of my towing capacity. But, when I figure tongue weight, gear, passengers, bicycles on the front of the truck and two kayaks on top I am probably exceeding my truck capacity. DW says I should go on a diet.
2013 Ford f-150 5.0 3.55
2015 Rockwood 2703ws
Rockwoodjoe is offline   Reply With Quote
Old 12-05-2015, 09:20 AM   #70
Oaklevel's Avatar
If you are commercial can be a different story but the likely hood of of any citation or law suit for being a little overweight is SLIM TO NONE unless it is grossly obvious........... If you are towing a 10000 lb TT with a Ranger maybe....... although a local guy has a duelly Ranger
Most of the trailers I pull don't any longer have the weight ratings due to sun fading & I have a 10000 lb permanent tag on my single axle box trailer (Way over what it can carry) And .......... you can not necessarily go by the number of studs the axle has either........... So it is not always an easy thing to prove........ one way or the other................
Doing the right thing is important being paranoid is crazy........
1966 Mustang GT
1986 Mustang SVO
towing
