01-21-2016, 09:11 PM
Towing a 2015 wildwood with a 2015 Ford F-150 eco boost
Hi my wildwood weighs 6789 dry. I have pulled locally no problems. But wondering if enough vehicle for long trips, safety issues etc. any ideas?
Jim and Ruby
01-21-2016, 09:15 PM
depends on how your truck is optioned. There is a wide range of towing capacities and payload ratings.
David & Lynn 2014 Coachmen Chaparral Signature 327 RLKS 2016 Ford F350 Lariat CC Dually
01-21-2016, 09:36 PM
Jim and Ruby
My 2013 F150 Ecoboost 3.5 pulled my 6500 + lb (loaded) Surveyor 11K miles this year with no truck issues. I have replaced the brakes with a complete set of drilled/slotted PowerStops with their Z36 towing pads. I also added a set of AirLift 5000 Ultimates to help level the truck.
01-21-2016, 10:01 PM
I'm about 1000 lbs higher weight dry on my 5th wheel and have no problem with it going long distances other than the pain at the gas pump. I have road master active suspension on the leaf springs and love how they handle loaded/unloaded.
01-22-2016, 12:21 PM
You should have no problems. I have the max tow pack on mine and am rated to tow 11,900 lbs (for a travel trailer) and 10,500 lbs for a 5th wheel.
Marcel & Jenne
Kemptville, ON
2014 Rockwood 8282WS
2015 Ford F150 Eco-Boost
01-22-2016, 12:39 PM
I have a 2011 Eco boost installed load range e tires big difference the general purpose tires don't cut it other than that the only issue is when big rigs pass you I installed a helwig sway bar and it has helped big time. Enjoy and safe travles
Clancy vibe272bhs
01-22-2016, 01:17 PM
Jim and Ruby
If you have the tow package on the truck which I assume you do, don't even give it a second thought. Enjoy. Speed is the gas mileage secret. I'm pulling a hell of a lot more weight than you are and if I keep it a 55 I get in excess of 12 MPG At 60 I get about 11.5 MPG. I don't drive any faster than that because I'm never in that much of a hurry.
Richard Charron
Zephyrhills, FL
2015 Ford F150 Eco Boost
2016 Coachmen Chaparral Lite 29MKS
01-22-2016, 01:20 PM
ARLO
Clancy vibe272bhs
Very good move.
01-22-2016, 02:59 PM
I've pulled a 3029 Windjammer (dry weight 7469 lbs/loaded 8200 lbs) with an F150 Ecoboost 3.55 for 8,000 plus miles with out any issues. No modifications on either the trailer or truck.
01-22-2016, 03:24 PM
Do you know gearing your truck has? CCC weight? (Yellow sticker inside drivers door). Ford produces ECOs for high gas mileage......OR.....pulling / hauling.
I have the 6.5 foot bed (see sig) and with my dry weight TT at 5748, I estimate loaded weight at 6500lbs. I don't carry water, wood, generators, four wheelers, etc.
My combo is very smooth, quite and without issues. Here in the flats of Florida I average 9.5 to 10.5 MPG @ 63 MPH. 63 MPH just seems to be a smooth comfortable speed for me while I'm towing.
Again, check your tongue weight with your CCC.
Good luck.....Happy camping!
1930 lbs CCC
2014 Jeep Rubicon JK
01-22-2016, 06:52 PM
Thanks for all the replies, puts me at ease now. Just was curious but feel more. Confident now. Thanks Jim
01-24-2016, 07:53 PM
Jim and Ruby
Should be ok with Max tow on either EB 2.7 or 3.5 my 2014 pulled my 7,000# Shasta 32' up and down hills of PA with no issues my max tow is 11,200 and I never exceeded 8,000#'s
2014 F150 FX4 Crew 4X4 EB
2015 Roo 23IKSS
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
01-24-2016, 08:34 PM
I kinda figured would be ok. But just bought the 2015 F150 eco boost. And wanted to hear from others that pulled with the same vehicle. Thanks Again. Jim
01-25-2016, 07:25 AM
I have a dry weight of 5400 pounds. Loaded with family of 4, dog, generator, bikes, etc. I have only one concern...when trucks pass, I can feel the "suck". I use a WDH and friction sway bar. Next step is LT tires.
In the flats it is truly a dream. In the mountains, I dig into the throttle very rarely.
My mileage for the last year was averaging 10.5. However, my last 600 mile trip struggled to get 9.5. There must have been winds I was fighting and didn't know it.
This same truck towed our last trailer (4k pounds) all over the Rockies like it wasn't even with us. In the 6k mile trip we averaged 12 mpg. It was an amazing truck at that weight. With my new weight, it no longer feels "amazing". I just give it a "very capable" rating.
2013 F150, EBoost,4x4,CC, MaxTow
2015 Surveyor 245BHS
01-26-2016, 07:32 PM
I have a 2011 ecoboost with max tow. I have been pulling a 35 ft fiver at 9800 lbs for 4 years and 30,000 km all over US. With no problems. We just ordered a 42 ft heritage glen at 10,600 lbs. I added air bags in the back of the truck for about $500 which took the towing from 11500 lbs to 13500 lbs. I also found out, 2 years in, that the stock tires are 4 ply only. I had been overloading my tires. I upgraded to 10 ply michilins. They are at 40 most of the year and then 70 lbs when I am towing. The ecoboost has never had a problem with power. I compared a neighbour how had a f250 desiel and he got 25.6 km/100 where I used 28.8km/100. I would have to tow over 100,000km to break even on the up-cost of the desiel Just my experience
01-26-2016, 08:30 PM
Not sure where you were told air bags and/or higher ply tires would increase the payload but it did not come from the truck mfg, the air bag mfg, or tire mfg as it does not happen Add helper springs too and you still have the TV mfgs payload with zero increase.
01-26-2016, 08:36 PM
you have been misinformed. Your ratings are the same. You have added stability and safety only. Your new 5th wheel when loaded will put you over your rated capacity, and I would bet over payload also.
01-27-2016, 10:07 AM
Wow I would never tow over 9800 with my 2014 F150 EB SCREW SB. Going up hills in PA I like to have a lot of wiggle room hence why I decided not to get an 800# Crusader 295 with a pin of 1520 even though my Pin goes to 2200 capacity. I now have a Rockwood Roo Hybrid 23ikss which is less than 6000# loaded and I have plenty of room. Switching to BFG AT KO2 with a 10ply and adding 2.5" air bags just for safety as I am adding the 2.5" front leveling kit to my truck.
I was thinking about an F350 SCREW Diesel regular box but can't justify the cost as I use my F150 as a daily driver
2015 Roo 23IKSS
01-31-2016, 04:43 PM
A 42 ft trailer being pulled by an F150 should be interesting.
01-31-2016, 05:19 PM
I'd like to see that ~~~ but not from the same highway..
