10-09-2014, 09:11 PM
Towing a 40' Travel Trailer??
We're looking at purchasing a new travel trailer. The floor plan we like is a large travel trailer about 40' total length around 9.5 to 10k lbs. Our TV is a Ram 2500 diesel which can easily pull it. Our last TT was 33' 6" long so we are used to towing longer vehicles.
I wanted to see others experience pulling something this long and what issues you had with it. We'd certainly buy a good hitch (probably pro-pride) to eliminate sway. It seems like the biggest issue is backing up a long TT but looking for input on anything else we should think about!!
Thanks!!
10-09-2014, 09:21 PM
We recently went from towing an 18 footer with a Tacoma truck to towing a 34 footer with a Tundra. Honestly, after driving around, my only concern was the extra stopping distance I noticed when testing out the brakes. (But I raised up the number on the brake controller which really helped.)
I drove longer trailers and things when I was in the Air Force and I think the rules for smaller trailers are the same for larger ones. (And, of course, never ever try to make a right turn from the right lane into the right lane of that road...you'll hit something!!)
My main rule is when in doubt about a turn, go straight and find somewhere safe to turn around...better safe than to hit something.
Happy trails!
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
8-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
10-09-2014, 11:00 PM
Good advice! Thanks!
10-10-2014, 12:15 AM
JMHO but I'd never buy a 40' TT. Not because of the towing aspect but because I really doubt the integrity is there. IMO a 36' 5'er would be the better choice. I haven't seen any 40' TT's that are built on a strong enough frame with adequate suspension.
CCC's are usually quite low as well as holding tanks.
10-10-2014, 03:43 AM
Just remember you added 6' behind you so make your turns a little wider. 40' is pretty long and I don't know what kinda of camping you do, but it might limit you in some of the older parks where spaces are closer together for backing in. If your pulling 34' already it not such a big jump. Good Luck and happy camping...
Coachmen M/H
Concord
2018 / 300 DSC
10-10-2014, 04:31 AM
I am pulling 39' 5th wheel with a long bed dually. Doesn't turn on a dime, but pulls easier than the bumper pull unit we had before this one. In addition to the comments above, I would add to never attempt backing without a competent spotter. It seem like every time I attempted to back the unit without the spotter, I ended up with a close call.
BTCM(SW) Ret USN
2013 Sanibel 3500
2013 Ram Truck 3500 Laramie Longhorn Dually
10-10-2014, 05:07 AM
Can't speak for a bumper mount but, we went from a 30' 5ver to a 36' 5ver and it tows better and backs better.
2021 Alpine 3790FK
2021 F-350 SD XLT PS 6.7 Dually Longbed 4wd Crew Cab
10-10-2014, 06:58 AM
We have the wildwood 36bhbs which measures a little over 37 feet to the tongue. Trailer it all over and never have a problem. Just have to take a little more time and patience.
Life is a highway!!!!!
10-10-2014, 07:29 AM
My Lacrosse TT is 38'6" long and tows great with my 2500HD. Length can be a issue in older or small site cg. When we went to Ky last year I used google earth's measuring tool to help pick a site. (worked great)
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
Seasonal
Zelda the campin dog
10-10-2014, 08:16 AM
Wow. Thanks. That's a great tip.
regards,
Extremebike
2004 Ford F550 6l Lariat SuperCrew, Fontaine Bed,
Link Systems Air Ride
2011 Sterling 32RL with Michelin XPS tires
10-10-2014, 08:26 AM
I saw on a youtube video that the #1 place for RV accident claim was at gas stations where the RV didn't clear a corner and hit one of those metal or concrete barriers next to the pump.
That's why we LOVE finding a nice, big truck stop to fuel up!!
Rick & Karen
Monument, Colorado
10-10-2014, 08:29 AM
Problem with a 40' bumper pull TT (we had a 36') include:
Ability to get into/out of gas stations/shopping plazas
- More gas stations moving pumps perpendicular to the road
- Are there steep grades into/out of the plaza/gas station
- Shopping plazas adding more islands/obstructions getting into their lots
Ability to get into/out of sites at campgrounds
- Tree clearances on both sides of the roads (your swing will require it)
- Has someone parked their vehicle on the other side of the street where you need to swing
- Is there room to park your truck on the site once you are setup
- Can you get into the campgrounds where you typically camp
Keep in mind your total length = 40'+ TT + 18/19' TV = Probably over 60' depending on if you have long bed/short bed/crew cab, if the 40' includes length of hitch and such.
Highly recommend drag wheels be mounted (very heavy duty) on the rear frame (not the bumper) to prevent bottoming out. If they are heavy enough you will not need to worry about your bumper being damaged.
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
10-10-2014, 09:27 AM
I used to tow my brothers 36' TT/ 40' overall. It's long as a bumper pull. It should pull ok as long as your properly setup. Something this size will limit you when choosing sites or CGs. You will never have the maneuverability of a 5th wheel with this. Turning will be wide. I pull a 43' 5er, and I pre-plan trips and roads before leaving.
I used to have a really nice motorhome
2016 Jeep Wrangler Unlimited
10-10-2014, 10:15 AM
Thanks that's good info on the measuring tool. I tow a 41.5' 5er and it doesn't seem any longer than our 35' TT since its a 5er but it sure doesn't turn as sharp as our TT did. So wide turns is a must and watch height and sides real good at all times. I don't like trying to find a place for fuel. LOL
Thinking about an 100 gallon aux. tank. At 9 to 10 mpg my trucks 40 gallon tank seems limited. LOL And to Top it all off the 5er has a 30 gallon tank also.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
10-10-2014, 10:43 AM
Thanks for all the input from everyone!!
We actually looked at 5ers first but we need a level floor plan throughout and I use the bed of my truck when traveling/hunting. The TT fits what we do a little better even though its all behind the truck.
Fuel stations.... Even with our 34' TT I was pretty selective on where to fill up.
Does anyone have a backup camera on the back of the TT or 5er to help with backing up?
10-10-2014, 10:46 AM
No camera just a woman director and sometimes I'm sure the camera would work better. LOL Don't tell her I said that.
10-10-2014, 11:55 AM
Yes had a backup camera - "wireless" but ran the extra wire back to turn on/off when in reverse
Walter & Donna
10-10-2014, 12:47 PM
hope she's not
Seasonal
10-10-2014, 01:43 PM
Mddle of the Rd Extremist
You should listen to this guy.....really
Dan, Carolyn & The Bandit (1999-2015 RIP...)
MCPO (Retired)
United States Navy ('65 - '87)
2014 Cedar Creek 38FL
2013 RAM 3500 6.7L diesel DRW Crew Cab
"When you get to the fork in the road, take it....."
10-10-2014, 04:29 PM
With the storage rack on the back I sit at 38'5" . No real issue to speak of....generally If someone can get their 29' somewhere i can too.
I do have to pay special attention when making reservations to specify my needs...and that can eliminate some spots. But i havent had issue yet.
Right near 10k loaded. I use a basic husky tow hitch wirh 1200lb bars and one sway arm. ..once set up CORRECTLY it tows as fine as any other trailer I ever pulled.... 5er or goose...
Never drag..but some trailers ride low ....
I guess its all relative...if your used to a pop up, then yeah....I could see a 40' trailer quite a transition....
2015 F350 Platinum Fx4 6.7 Diesel Dually. B&W turnover, B&W Companion, air bags and wireless controller.
2015 Heartland Road Warrior 420 Rt
2012 f250 Fx4 6.7 Diesel crew cab tinted n tuned
2012 lacrosse 318bhs touring- sold
