Old 12-10-2015, 12:30 PM   #1
CWSWine's Avatar
Towing a 5er Level
I know that level is where you should be but if you have lowered the hitch to lowest setting and raised the pin to highest setting and still 2 inches high is worth going to all the trouble to raise the 5er? I have talk to people that like the nose little high to people that they have towed 5 and 6 inches high for years. I was told by the dealer not to worry about a couple inches since I have the MorRyde suspension and that will equal out the weight between the front and rear axles and shouldn't be a problem.
I was told the main reason to tow level is shifting the weight from the forward axle to the aft axle and over load the rear axle on the 5er. Is that true or is there other reasons you need to tow level?
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 12-10-2015, 07:18 PM   #2
26ddss's Avatar
I've got the same question. Hoping that some with experience will chime in on your post...and maybe also visit mine.
Good luck and I wish you many years of happy camping.
RJ
26ddss is offline   Reply With Quote
5er, towing
