Old 09-03-2016, 12:32 PM   #11
W5CI's Avatar
I had a 3/4 ton GMC gas and went to the 3500 DRW RAM Cummins there is no Comparrision in towing ability. If you shop around you can get a 1 ton cheaper than a 3/4 ton especially a DRW
2004 Cedar Creek 30RLBS MORryde IS/Disc Brakes
2015 RAM 3500 DRW 6.7 Cummins 3.42 Garmin 760RV
Firestone Air Bags/Air Lift Wireless One Controller
40 Gal TransferFlow fuel tank
Amateur Radio W5CI AR-0043-29 2016 Days Camping 50
2017 Days Camping 8
W5CI is offline   Reply With Quote
Old 09-03-2016, 07:29 PM   #12
CWSWine's Avatar
Picture is worth a thousand words..... Capture from....
Matching Trucks to Trailers
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
Sold - 2014 Cougar SGS
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 09-03-2016, 07:36 PM   #13
CaptnJohn's Avatar
Enlarged, printed, and will laminate that! Will keep it in my truck to TRY to explain ~~ but some refuse to understand.
2016 Keystone Cougar 303RLS
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
Old 09-03-2016, 08:11 PM   #14
CWSWine's Avatar
Some people believe that what they put in their bed of truck is cargo but since the 5er hitch attaches to the frame it isn't in the bed and doesn't count as payload.
Old 09-03-2016, 08:54 PM   #15
CWSWine's Avatar
CaptnJohn
If you want to print something this great flow chart I saw a few month ago.
Old 09-03-2016, 09:32 PM   #16
DDC
DDC's Avatar
I have a 2017 33IK and tow with a chev 2500HD 6 1/2 foot box, tows well use a BD3 air ride hitch no slider.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 09-03-2016, 09:38 PM   #17
CaptnJohn's Avatar
Thanks. I don't believe anyone towing overloaded cares enough to make changes, not even if towing with white knuckles. The majority probably don't know and since the truck and or camper salesperson told the they are fine their minds will not be changed. Well, some care and some will adjust but a minority imo. From what I've seen I think TT owners are more open to getting numbers correct than those with 5ers or MHz.
2016 F350 diesel
Old 09-04-2016, 06:29 AM   #18
mbbutler's Avatar
Take this forums advise. A dual rear wheel truck is best for 33IK. My trucks rear axle weight loaded is 7100#. Ford F-250 SRW.
mbbutler is offline   Reply With Quote
Old 09-04-2016, 07:29 AM   #19
We went from a 3/4 ton truck to a Chevy 3500SRW. Very stable on the roads and it pulls our 34 ft 5th wheel very smoothly. I upgraded to a 1ton because I knew the truck was overloaded. Lots more stopping power and no sway when big rigs pass me. Common sense tells you that being overloaded is potentially dangerous as well as opens up liabilities should an accident occur.
Costs a bit more, but well worth it.
TXCPL is offline   Reply With Quote
Old 09-04-2016, 09:05 AM   #20
NMWildcat's Avatar
If you are buying a truck, get the most truck you can. I'd rather have too much truck than just enough. On newer trucks the ride difference between 2500hd and 3500hd is not much. SRW or DRW? Depends on preference and if it's a daily driver or not. We prefer SRW for overall use.
Before you buy a slider hitch for a 6.5 bed, look at the sidewinders. Much better solution. I find sliders to be too heavy, take up too much room, and seem to bind when you need them most. If it would fit in my garage, I would prefer a long bed for towing though I find them aesthetically unattractive. Then no need for special hitches.
Enjoy your new rig!!
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
cedar creek, towing
