09-02-2016, 10:12 AM
Towing a Cedar Creek 33IK
DW and I are new to the forums as we are buying the 33IK and a truck in the next few weeks. Two questions:
One CC salesman says I have to use a Chev Duramax 3500HD. The second CC dealer says a 2500HD will do fine.
Secondly, will I need to use a slider hitch if my truck has a 6 1/2 bed? Pros or cons?
If we pull this off we will see you all out there.
Jim and Janet
09-02-2016, 11:50 AM
To be sure you get the right truck, look at the gross vehicle weight rating of your prospective trailer then multiple by 20-25% which will give you the pin weight of the trailer when fully loaded (I would use the 25% factor to be safe). Then compare that with the Payload capacity of a 2500 & 3500 truck you are looking at. When you look at the payload capacity, don't forget to subtract the weight of any passengers, your weight over 150 lbs. if that applies and gear you may carry in the truck. It is not uncommon when towing a 5th wheel to find the pin weight is close to, at, or exceeds the payload capacity of a 2500. If the results are at or just under, you might consider a 3500 anyway as for not a lot of $$ more it will give you more payload capacity, which is nice to have the flexibility.
Regards, Bruce
Current TT: Northwood Snow River 246RKS
2015 Ram 3500 DRW Cummins Diesel w/AISIN Tranny
09-02-2016, 02:34 PM
Jim and Janet
Do you already have the 3/4 ton truck?
Some will tell you that you can get by without a slider hitch for a 6'-5" box, because of the new style caps and the extended pin boxes.
Will in my very humble opinion I would buy the slider hitch. It is better to have and not need the hitch than to find out after you have failed the window and dented the cab that you needed the slider hitch.
I have always owned short bed trucks and I do have a slider hitch. I use the hitch occasionally when I am in very tight campgrounds and putting the camper in the driveway at home. Otherwise the hitch is in the towed position and I can drive anywhere I need to drive when towing my 5er.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
09-02-2016, 09:48 PM
Jim if you go gas 2500 there good chance you will have enough payload but you will probably exceed the Gross Combine Ratings. If you diesel 2500 you will have the tow capacity but probably be over your payload. With 1 ton most likely you will be under all the manufacture specs.
Really good video on how to match your truck to your rv
Matching Trucks to Trailers
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
09-02-2016, 10:10 PM
I can't speak to Duramax as I have a F250 and pull a 33IK. I am over payload. Truck pulls fantastic and I don't notice any issues but I know I'm over payload. I have a diesel (only way to go IMHO when you get to bigger toys) but this eats into payload. My buddy just bought a new Montana 5ver and was looking at a 250 and I convinced him to go SRW F350.
My recommend is get the 3500 SRW. I don't know about Chevy but Ford the price difference is about $1000. You will have plenty of payload and when you upgrade you will be set.
BTW I am completely happy with how my F250 tows and will be keeping the F250 even though the WP on this site will have a diffent opinion..
09-02-2016, 10:18 PM
I agree...
I started out with a 3/4 ton Chevy diesel towing a fifth wheel copper canyon with a slider hitch, only has to use slider once. was not happy...traded camper and truck in bought a cedar creek and new Chevy 1 ton dully best investment in my opinion. Like what the above says, you are not paying much more for a 1 ton...like the duel wheels in the rear you don't get the rocking side to side like a single wheel truck. My 3/4 ton rock and roll side to side, don't have this issue with my dully.
2014 cedar creek 36ckts
2014 Chevy 3500 1 ton crew cab 4x4 long bed.
09-02-2016, 10:32 PM
Originally Posted by cfiowa
I agree...
I don't have any rock and roll with my SRW F250 but I'm sure the DRW adds to stability. I also have the short bed and I recommend getting a slider. I have never used mine as the front of the 33IK is shaped to allow a pretty sharp turn but I can't do a 90. Pretty close but no way. Let me tell you a story about my buddy I convinced to get a F350. He got a slider hitch but did not use it the very first time he backed his brand new Montana with his brand new F350 into his driveway. He remembered me saying I've never had to use it. Pow, blew out a rear window. The Montana cap design and the 33IK cap design are completely different. Get the slider! It does not have to be automatic but you want the option. Just remember depending on the truck and payload when you start adding auto slider capabilities you are also eating into payload...
09-02-2016, 10:49 PM
Go with the 3500, duramax/allison
2014 Chevy CC Duramax 4X4 Long Bed
2017 Cedar Creek 36CKTS
MORryde independent suspension with disc brakes
09-03-2016, 12:42 AM
I had a F250 diesel with the camper package. I was well over payload even if it were a gasser. I bought an F350 SWD diesel. I have zero sway and do not notice when semis pass or I pass them. If the poster with the 2500 noticed sway and the F250 does not, that alone should eliminate the 2500. Often you can purchase an F350 at the same price or very close to the same as an F250. Well worth being under all weight numbers.
The Ford short bed is a few inches longer than the Chevy but I still have a slider. It does add more weight and I rarely use it, but when needed you will be overjoyed it is there. Another reason for the F350. Nothing like a diesel for the torque, HP, and engine brake descending steep hills/mountains. Seriously, a 2500 or 250 is only a slight step up from a 1500/F150.
2022 Montana 3855 BR
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
09-03-2016, 12:18 PM
You will never be sorry you got the F350. It is awesome! In the mountains you don't have to worry about going up or down.
09-03-2016, 12:32 PM
I had a 3/4 ton GMC gas and went to the 3500 DRW RAM Cummins there is no Comparrision in towing ability. If you shop around you can get a 1 ton cheaper than a 3/4 ton especially a DRW
2005 Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2019 Days Camping 25
2020 Days Camping 7
09-03-2016, 07:29 PM
Picture is worth a thousand words..... Capture from....
09-03-2016, 07:36 PM
Enlarged, printed, and will laminate that! Will keep it in my truck to TRY to explain ~~ but some refuse to understand.
09-03-2016, 08:11 PM
Some people believe that what they put in their bed of truck is cargo but since the 5er hitch attaches to the frame it isn't in the bed and doesn't count as payload.
09-03-2016, 08:54 PM
CaptnJohn
If you want to print something this great flow chart I saw a few month ago.
09-03-2016, 09:32 PM
I have a 2017 33IK and tow with a chev 2500HD 6 1/2 foot box, tows well use a BD3 air ride hitch no slider.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
09-03-2016, 09:38 PM
Thanks. I don't believe anyone towing overloaded cares enough to make changes, not even if towing with white knuckles. The majority probably don't know and since the truck and or camper salesperson told the they are fine their minds will not be changed. Well, some care and some will adjust but a minority imo. From what I've seen I think TT owners are more open to getting numbers correct than those with 5ers or MHz.
09-04-2016, 06:29 AM
Take this forums advise. A dual rear wheel truck is best for 33IK. My trucks rear axle weight loaded is 7100#. Ford F-250 SRW.
09-04-2016, 07:29 AM
We went from a 3/4 ton truck to a Chevy 3500SRW. Very stable on the roads and it pulls our 34 ft 5th wheel very smoothly. I upgraded to a 1ton because I knew the truck was overloaded. Lots more stopping power and no sway when big rigs pass me. Common sense tells you that being overloaded is potentially dangerous as well as opens up liabilities should an accident occur.
Costs a bit more, but well worth it.
09-04-2016, 09:05 AM
If you are buying a truck, get the most truck you can. I'd rather have too much truck than just enough. On newer trucks the ride difference between 2500hd and 3500hd is not much. SRW or DRW? Depends on preference and if it's a daily driver or not. We prefer SRW for overall use.
Before you buy a slider hitch for a 6.5 bed, look at the sidewinders. Much better solution. I find sliders to be too heavy, take up too much room, and seem to bind when you need them most. If it would fit in my garage, I would prefer a long bed for towing though I find them aesthetically unattractive. Then no need for special hitches.
Enjoy your new rig!!
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
