Old 10-02-2014, 09:23 PM   #31
wbdavey's Avatar
Originally Posted by MagnoliaTom View Post
Actually got that info from the ford truck forum. The point is there is no difference between the two. Ford just gives a higher weight rating to the f350. Springs are identical. I suppose they get away with it because of the spacer and badging
I ordered a new 2005 F350 SRW that had the heaviest of FOUR available GVW ratings (without DRW) and a cargo capacity of 4,100 pounds. I know the heaviest F250 availble that year had a payload of about 2,850 pounds, that's why I bought the F350. So your Ford forum information is not correct. You already know you're overloaded so I'm only trying to correct the information you used to decide it's OK.
2015 Rockwood Ultra Lite 2604 WS. Rear LR, large street side slide with small wardrobe slide in BR.
2014 Ram 1500 Eco Diesel Laramie Quad Cab.
wbdavey is offline   Reply With Quote
Old 10-02-2014, 10:21 PM   #32
MagnoliaTom's Avatar
Here's the link. Quite informative
http://www.ford-trucks.com/forums/11...r-and-faq.html
2014 Freedom Express 320BHDS Liberty Edition 50th Anniversary
2005 F250 Lariat SuperCrew 6.0 PS Diesel
2004 Excursion Limited 4x4 6.0 PS Diesel
2000 Excursion Limited 7.3 PS Diesel Sold:crying
MagnoliaTom is online now   Reply With Quote
Old 10-02-2014, 10:25 PM   #33
Originally Posted by davel1971 View Post
air bags DO NOT add payload capacity. If you don't want a dually, get a single wheel one ton. I love mine. Sits perfectly level with my 5th wheel on it and I carry plenty of stuff in bed too.
Did you read the part about the differences between a 3/4 ton and 1 ton?
Old 10-02-2014, 10:30 PM   #34
Note: I have not yet purchased the fifth wheel, hence I cannot yet know that I'm overloaded.
Old 10-02-2014, 10:44 PM   #35
ironj's Avatar
Ive used those figures as explanation many times. .... (although the original post is older, there is a link to newer trucks further down)......oddly enough I had a supposed "ford tech" argue that the axle info was misprinted and they were in fact the same on the 250/350....??..the axle rating is over 1000lbs more??..how could they be the same??..lol...whatever....its a fun debate regardless. ..
2015 F350 Platinum Fx4 6.7 Diesel Dually. B&W turnover, B&W Companion, air bags and wireless controller.
2015 Heartland Road Warrior 420 Rt
2012 f250 Fx4 6.7 Diesel crew cab tinted n tuned
2012 lacrosse 318bhs touring- sold
ironj is offline   Reply With Quote
Old 10-02-2014, 10:51 PM   #36
Yeah, some people think you're crazy to suggest the two trucks are equally equipped. I try not to talk to those people 😄
Old 10-02-2014, 10:56 PM   #37
jimdd810's Avatar
As a service tech for a long time and a salesman at a ford dealer two things come to mind. First it's not how much you can pull its how much you can stop. That's the major reason to make sure your tv brake systems are what's needed with room to spare and they are well maintained. 2 weight does come into play. 200 to 300 lbs isn't a lot but 500 and up makes a major difference. I recommend trying to pull the trailer first before buying it. Specially if your going to be towing it all over.
Life is a highway!!!!!
jimdd810 is offline   Reply With Quote
Old 10-02-2014, 11:06 PM   #38
That's an excellent suggestion.
Old 10-02-2014, 11:09 PM   #39
Btw, all brake pads recently replaced with Wagner heavy duty pads. Brake fluid flushed. System working as well as can be expected.
Old 10-02-2014, 11:17 PM   #40
GreenImp's Avatar
Send a message via MSN to GreenImp
If I were going to intentionally tow over my payload capacity and/or my RAWR, I would be more concerned about upgrading my rear tires than adding airbags. Airbags only help the ride quality and the look (sagging). Every RAWR I have ever checked out was exactly equal to the weight rating of the original rear tires combined. This is obvious (to me) proof that the rear tires are the weak link. Upgrading the tires (and wheels if necessary) would actually add an additional level of safety that airbags do not. In the event of an accident and lawsuit, a good lawyer could easily convince a jury this method was acceptable (assuming you were within all other ratings). I can assure you that as a juror, I would take this "realistic" approach vs a "by the book" approach.
And now that I think about it...I wouldn't be surprised to find that the tires are another difference between the F250 and F350 models. I wonder what the weight ratings of the tires on the new trucks are.
'04 GMC Sierra 2500HD, CCSB, D/A, MaxBrake, B&W Companion, Retrax Pro, AR Power Steps
2013 Rockwood 8289WS w/Diamond pkg
1969 Camaro RS/SS Convertible
Dad's old 1968 Empi Imp (recently recovered from under 21 years worth of boxes/dust)
GreenImp is offline   Reply With Quote
fifth wheel, towing, wheel
