04-14-2019, 05:35 PM
Towing a Jeep Wrangler
I have to leave the key on just enough to unlock the steering. That puts a light on in the dash or radio but I didnt think that should kill the battery, but it does or has. I found the fuse that turns the light out. Oddly when I start the engine every thing seem fine but it reads out in the dash "Fuse removed"
Probably does'nt hurt any thing but I read the manual and it says to disconnect the negative battery terminal.
So I did that since it might even be easier than pulling the fuse.
What do you guys do when pulling your Wrangler?
04-14-2019, 06:44 PM
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
04-14-2019, 07:23 PM
On our 2004, turned the key one click and it never drained the battery. I usually run it for 5-10 minutes at a stop,along the way. But have towed it for 8-10 hours without draining the battery. What year is your Jeep?
2020 S.O.B.
2016 Jeep Wrangler 75th and a
Cooler full of good ideas
Full Time in the Summer, soon
Part Time in the Winter
Days Camped, Not Enough
04-14-2019, 08:06 PM
I remove the key from my '15 JK. No steering lock.
BIRDS AREN’T REAL
04-14-2019, 08:12 PM
Thanks emm-dee. That answers my question cause I just traded the 2004 TJ for a 2016 JK.
2020 S.O.B.
04-14-2019, 08:28 PM
did a little research and found that Jeep removed the steering lock during the 07-08 model years but did not update the owners manuals. However, some have reported that some models up to '14 still had a steering lock. And, some pre-'07 did not have a lock.
Go figure.
BIRDS AREN’T REAL
04-14-2019, 08:33 PM
you can also add a roadmaster charge line to the 6 pin plug from the RV. It is very easy.
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
04-14-2019, 08:50 PM
Did you mean seven pin connector? I don't think most motorhomes have six pin connectors.
BIRDS AREN’T REAL
04-14-2019, 08:57 PM
yes it pulls from the RV seven pin to the 6 pin plug on the jeep. It is a wire that is run from the aux pin on the jeep 6 pin plug to the jeep plug. The power comes from the rv 7 pin plug 12v pin
2011 Jeep JK Toad
04-14-2019, 09:09 PM
OK, understand. My Jeep doesn't have a six pin...only a 4-pin on the front bumper to connect the lights.
BIRDS AREN’T REAL
04-15-2019, 04:48 AM
Emm-dee. What year is your wrangler?
2020 S.O.B.
04-15-2019, 06:01 AM
2015
BIRDS AREN’T REAL
04-15-2019, 07:05 AM
I’m pretty sure you don’t have a steer lock. Check your manual or park on a hill put it tow mode and leave the key out. let it roll so you can turn the steering wheel. You will know if you have a steer lock. I searched a couple of Jeep forums and they all say the steering lock stopped somewhere around 07-08.
2020 S.O.B.
04-15-2019, 07:11 AM
When I hooked up the Ready Brute system we did a brake test. I rode in the Jeep while it was being towed to observe and verify brake pedal movement. The steering wheel was definitely turning left and right with no interference from a steering lock.
BIRDS AREN’T REAL
04-15-2019, 07:33 AM
Emm-dee / CZNEDY - are you attending the Peach Rally this year ? If so, maybe we can find & take the Jeeps out for some trail rides !
Also - my 14 has no steering lock !
1930 lbs CCC
2014 Jeep Rubicon JK
04-15-2019, 09:26 AM
Sorry, no we won't be there. We are going to the Tadpole and hopefully the Goshen rally but that's it this year. We have a cross country trip planned for October so only two rallies. Maybe next year. Thanks,
2020 S.O.B.
04-15-2019, 12:26 PM
Same on my 2018 JK
04-15-2019, 12:47 PM
We will be there.
BIRDS AREN’T REAL
04-15-2019, 12:57 PM
I don't know the year of your Wrangler, but I have no such problems with my 2006. I did discover early on, however, that after putting the transfer case in neutral and turning the key to the off position, I needed to be careful to not continuing to turn the key to the accessory position. Turning the key beyond the first stop allows the accessories to drain the battery such as the radio, wipers, etc. Thus my battery was drained and I had to recharge it before operating the Jeep again.
Hi Rider
Jack and his dog, Amber
2016 Forester 2401W MBS pulling 2006 Jeep Wrangler
2020 - 162 Days and 5,359 Miles
2021 - 113 Days and 3,835 Miles
2022 - 35 Days and counting, and 3,372 Miles and counting
04-15-2019, 02:47 PM
I have a 2016 JK Willy's, love it. Tows great.
2016 Dynamax Isata 3 24FW
2016 Jeep Willys JK
Yellow Lab Buddy Biscuit Eater
USN-RET/DOD-RET
