Originally Posted by Gopherdave
The bumper is bolted to the frame. I was hoping that the bumper could be used to tow the jeep
It is my understanding that the tow bars must be attached to brackets that are attached/bolted directly to the frame. I have a Rock Hard 4x4 bumper with their tow bar brackets and the bolts go through the brackets, through the bumper and into the frame horn. So they bolt directly to the frame. The D-rings are attached to the recovery points like you have and the break away cables are attached to those. See my video on it below.
There are tow bar base plates as well that mount under the bumper. You can get those for the manufacturers of the tow bars. Blue Ox, who I use, has a base plate. They work with the stock bumper so you will need to check to be sure they work with your bumper as well.
