Old 02-21-2019, 09:53 AM   #1
Towing a new Cedar Creek Silverback, shortbed friendly?
Does anyone know if the new CC Silverback turning radius is short bed friendly? I am considering a 31IK but see no mention of its short bed compatibility (without using a slider hitch) in any of the documentation. Even the dealer is not sure and says he contacted FR but I have not heard back. I do know they changed the cap design recently.
PA-RV is offline   Reply With Quote
Old 02-21-2019, 10:54 AM   #2
Denver To Yuma In 90 Days
I don't think there is a 5'ver made these days that doesn't have the 88-90 degree turning radius.
I just looked at the FR website and the photos show that it has it.
Cedar Creek Silverback Edition 31IK - Silverback Fifth Wheels Fifth Wheels / Toy Haulers by Forest River RV
But with that big of a beast with a short box truck, I think you should still go with a slider!
What are you planning to tow it with?
Someone "doing it for years with no problems" doesn't mean YOU should!
2015 Heartland Prowler P292 5'ver, Reese 16K Pro Slider Hitch
2015 Chevy 2500HD 6.0L Gasser w/4.10 rear end
JohnD10 is offline   Reply With Quote
Old 02-21-2019, 11:05 AM   #3
What are you considering short bed? The 5.5' the 6.5' or the 6.75'?
I have had no issues in the past 20+ years with 6.5' and a 6.75' beds.
I do have a slider but have never used it in all these years.
If I get into a spot where I have to turn that short I'm more concerned about what it doses to the tires and suspension on such a sharp turn. Ever see how the tires and axles turn under when doing so? Not something i want to do. Back up and pull up a time or two will keep you from ever having to jackknife.
I once seen a guy twist an axle right out from under his trailer on a 90 turn on asphalt.
Days Camped: '15=22 '16=46 '17=30 '18=51
Old 02-21-2019, 11:19 AM   #4
I've never had to use my slider, but I'm glad it's there if and when I need it.
Old 02-21-2019, 11:48 AM   #5
Jim34RL's Avatar
I know for a fact that a 6'-5" bed will require a slider hitch sometime in your future. I have a sight dent to prove this in the C-Pillar of the truck on the driver side.
I even had a manual sliding Reese hitch but I did not extend the hitch to maneuver in a parking lot. I thought I could turn the truck and trailer without it but no I did kiss the cab, no broken rear window though.
After 10 years of use with the Reese manual slider it was scraped last year. I now have a Demco Auto Glide hitch so, I do not have to worry about extending the hitch any more. Will worth the money for this hitch no chucking at all and no worries about extending the hitch if I need to or not.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 123K+miles
Old 02-21-2019, 01:09 PM   #6
I do not want to use a slider hitch if I can avoid it. They are heavy to pull in and out. My goal was to use an Anderson hitch.
Old 02-21-2019, 01:19 PM   #7
Then you might just need to get a new truck with a long bed.
By the way...what truck are you planning to haul this with?
Old 02-21-2019, 01:43 PM   #8
Telstar's Avatar
My tow vehicle is a 2018 Ram 3500 with 64 box. Our Cardinal does not have the new front end so I chose to go with a Demco Auto Slid hitch for me it was the right decision, I can eaidly turn 90+ degrees.
That said, I dont plan on removing the hitch. Tilting it up for greasing is as far as I go. If you need a slider that you can remove I would recommend PullRite.
ID:	197269   Click image for larger version
Telstar is offline   Reply With Quote
Old 02-21-2019, 01:53 PM   #9
2017 CC Silverback. No slider.
Grumpy7159 is offline   Reply With Quote
Old 02-21-2019, 02:02 PM   #10
Uncle Monkey's Avatar
Hey Pa...I have a Silverback 29IK and a Short Bed Super Duty. I have a curt Q16 fixed hitch. You'll have no problems at all. They ARE short bed friendly. I have made some sharp turns, but do it slowly, with caution, and watch very carefully. Not problems at all.
I am trying hard to be as good as my dog thinks I am...
Uncle Monkey is offline   Reply With Quote
bed, cedar creek, towing
