Old 03-13-2014, 03:08 PM   #11
Towing a silverback 29re
Thanks everyone for your input. This is our first 5th wheel and it is good to get feed back from other owners. I've pulled smaller travel trailers with a Chevy avalanche. Before we buy a tow vehicle for our 29re I want to do a lot of research, so we don't regret our purchase. A follow up question; what is every ones feelings on diesels compared to gas? I know diesels last forever but I also know that repairs cost more along with general maintenance.
damian bryce is offline   Reply With Quote
Old 03-13-2014, 06:31 PM   #12
Once you tow with diesel power, you will not go back to gas
Of all the things I've lost in my life the thing I miss the most is my mind!
prairiecamper is offline   Reply With Quote
Old 03-13-2014, 06:42 PM   #13
N3HCP's Avatar
We've pulled out Silverback 29RE with both a 2011 F-250 6.2L gasser and our current 2013 F-350 6.7L dually. We traded the because of the weight restrictions of the F-250. We were right on the edge of what we could tow with only a couple hundred pounds safety margin. That said, the diesel makes the driving a lot more pleasant. The gasser always seemed it was working near it's limit while the diesel hardly notices the trailer at all.
The initial cost is something like $8,000 more then a gasser, the maintenance cost is also higher (it takes 13 quarts of oil, after all) and the new EPA required stuff makes then a lot more complicated.
That said, I'm not going back to gas anytime soon!!
2013 F-350 Diesel Dually, 6.7L with 3.73 rear with 50 gallon Transfer Flow aux fuel tank, ScanGauge II, Tire Minder on all 10 tires, 2M ham radio, and the ever popular CB.
2014 Surveyor SVF-293RLTS
2014 Clipper 16FB
N3HCP is offline   Reply With Quote
Old 03-13-2014, 07:19 PM   #14
Fulltime family RVer
Threads in the hundreds of posts have been written on this subject.
One of the biggest benefits to diesel is that I can use truck stops and truck pumps. No height restrictions or having to wiggle around the front-side of gas stations. Easy in, easy out.
Lots of people do it with gas- I just have found for me, I prefer diesel.
Old 03-13-2014, 08:30 PM   #15
Camper Less Camping
Cajun Po-Boy's Avatar
Gas vs Diesel...
I'll put it this way...do I want to walk the 10K marathon weighing 300lbs or 200lbs?!
I can complete it easier, enjoy the experience more and have absolutely no concerns on any elevation changes at 200lbs!
Yes, diesel does cost more upfront and a little more for maintenance but is sooooo nice when you hook up and tow ,)
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
towing
