Old 08-28-2012, 07:08 PM   #1
Question towing a wildwood 26bh with a ford flex
We are thinking about trading in our tent trailer for a 2011 wildwood 26bh. I know it is very close to our max towing of 4500 but just wondered if you guys had an opinion
bwerner333 is offline   Reply With Quote
Old 08-28-2012, 07:55 PM   #2
Dave_Monica's Avatar
Welcome to the forums!
I'm assuming that you're looking at a Wildwood X'Lite 26BH. To answer your question, the dry ship weight of the camper is listed as 4313#...the actual weight will be probably 300 to 400# more. With your Flex tow limit of 4500#, this isn't at all doable. The camper loaded for camping will be closer to 5800#.
Sorry, but I'd suggest that you look at smaller campers with a max GVWR of 4500# if you're intent on towing with the Flex.
Dave
Old 08-28-2012, 07:58 PM   #3
Road-King's Avatar
X2... But the sales-person might tell you "No problem"
Russ & Kim
2014 Alpine 3600RS
2007 Dodge Ram 3500 5.9 4X4
2008 Harley Davidson Road King 105th Anniversary
(2011-5 bad year)(2012-40)(2013-45)(2014-23)
Road-King is offline   Reply With Quote
Old 08-29-2012, 08:44 PM   #4
bikendan's Avatar
you need to read more about towing specs.
first, that trailer is nearly 30'!!
second, your Flex's 4500lbs. tow capacity is with only a 150lb. driver in it. any additional passengers or cargo, lower the 4500 by its weight, including the WDH's weight.
the trailer has a fictional "dry" weight of 4050lbs. this does NOT include the weight of so-called "options" that nearly all trailers have, such as:
awning, oven, a/c, spare tire, microwave and so on. so, a ballpark number would be to add 400lbs. to the "dry" weight, to get the actual weight from the factory. so, expect it to weigh very close to your 4500 max.
now, you still have to add the weight of the battery, propane and water before you even try to add the weight of the cargo.
third, the "dry" hitch weight of 410lbs. will easily be over the Flex's max tongue weight when loaded for camping.
bottom line: too long of a trailer, too heavy of a trailer and too much hitch weight.
Old 08-29-2012, 08:47 PM   #5
TURBS's Avatar
Couldn't agree more .
Old 09-03-2012, 07:36 AM   #6
there is other stuff to consider too
trailer weight is just one part of the total equation(you're over by the way)
the other factors are handling, braking and engine power
dragging 4000 lbs plus up a long hill takes a lot of power as does towing into any kind of head wind
1998 Forest River 21rb
2003 Ford Windstar
2 bicycles and a 3 yr old husky
stevem is offline   Reply With Quote
Old 09-09-2012, 06:31 PM   #7
I pull the same camper with a Camry.
Shaun is offline   Reply With Quote
Old 09-09-2012, 11:48 PM   #8
wyo700's Avatar
You must have the Hensley arrow hitch to be pulling that one off. 😁
2012 Sandstorm 203slc
2013 Toyota Tundra
Eqil-l-izer hitch,Prodigy P3
2014 Honda Pioneer 700-4
2004 Yamaha Grizzly 660
wyo700 is offline   Reply With Quote
Old 09-10-2012, 03:23 AM   #9
onequicksportster's Avatar
I'm sitting here at work working midnights, and I just read that and exploded with laughter. Thanks I needed that I was about to fall asleep.
2015 F250 psd CC Sb 4x4
2007 Wildcat 28rks 5'ver
2005 Harley Davidson
2009 Weimaraner "Dog"
onequicksportster is offline   Reply With Quote
wildwood, ford
