Old 10-22-2012, 12:07 PM   #1
towing advice
I have a new to me 2006 Shamrock 19ft trailer weighs in at 3500 and I will be pulling it with a 2005 avalanche. when hitched up it drops the hitch down 1 1/4 inches. The previous owner just had a friction sway bar, should I be concerned with a different setup or just leave it alone. The trailer is almost level just down a little in the front. Thanks Michael
Hornnumb2 is offline   Reply With Quote
Old 10-22-2012, 12:51 PM   #2
You shouldn't need sway control at all with such a short trailer and a truck with the wheelbase you have. Curious you have sway control but no weight distributing hitch.
crasher is offline   Reply With Quote
Old 10-22-2012, 01:02 PM   #3
Dave_Monica's Avatar
A good question about the lack of W/D hitch. Did you measure any change in height at the front of the Avalanche when hitched up. If you did, a W/D hitch would be a good idea. If it has a W/D, you may need to adjust the hitch head angle for proper W/D dependent on your measurements.
Dave
Old 10-22-2012, 01:21 PM   #4
Dave
I haven't measured the front but will next time I move it. Thanks
Old 10-22-2012, 01:36 PM   #5
It raised the front just a 1/4in. Thanks Michael
Old 10-22-2012, 02:18 PM   #6
Is it a weight distributing hitch?
Dave
Old 10-22-2012, 03:15 PM   #7
bikendan's Avatar
my advice, owning a Roo 23SS and an '07 Avalanche, is to get a WDH with sway control.
that weight of 3500lbs., sounds like the UVW, meaning without battery, water and cargo.
it'll weigh much more loaded for camping.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 10-22-2012, 03:15 PM   #8
Dave
No just a standard receiver with the little ball for sway.
Old 10-22-2012, 03:17 PM   #9
It has battery and propane but not loaded yet with anything else and the total weight was 3480.
What type or brand is recommended?
Old 10-22-2012, 08:19 PM   #10
bikendan's Avatar
the most recommeded WDHs, are the Equal-i-zer and the Reese Dual-Cam, since both have built-in sway control.
the E2(a budget Equal-i-zer with 2 way, instead of 4 way sway control) is a more affordable version.
i'm very happy with my 4 way Equal-i-zer. no drilling, no cheap friction bar and once mine was setup, never had to adjust it.
