Old 08-26-2015, 11:21 AM   #11
transamz9's Avatar
Originally Posted by TURBS View Post
Imo if you want to take toys, buy a toy hauler.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "24 nights"
Not a toy hauler made big enough to haul my toy.
2005 Ram 5.9 AT SB QC (Retired)
2010 Ram 6.7 G56 QC CC Aluminum flat/Leveled (Sold)
2008 Nitro Z9 towed by a 2015 Sanibel 3601 towed by a 2013 Ram 3500 SRW CCSB Cummins
2006 EZ GO 6" lift
transamz9 is offline   Reply With Quote
Old 08-26-2015, 11:38 AM   #12
Georgia Frog Rally 2018
aceinspp's Avatar
TURBS
2011 32bhok Sabre
X2 Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 08-26-2015, 11:39 AM   #13
aceinspp's Avatar
Wouldn't bet on it. Later RJD
Days camped 2017 62
Days camped 2018 18
Old 08-26-2015, 01:04 PM   #14
transamz9's Avatar
My toy is 102" wide and 30 foot long. Not many THers with a garage that big.
2006 EZ GO 6" lift
Old 08-26-2015, 01:14 PM   #15
I do not think this is a good idea. Several reasons, the first being single axle, your CCC is roughly 1100# and adding another trailer to that will eat into the CCC (TW), the strength of the frame, it is an ultra light, the extra downforce as well and the stress on pulling with the frame is most likely not up to the task.
What is the problem you are having? Just taking the ATV? why not use the truck bed with tail gate removed (if you had to)?
2018 XLR Nitro 36T15
2015 GMC 3500 6.6/Allison
Nights Camped (2017- 16) (2016-13) (2015-13)
SuicideSaints is offline   Reply With Quote
Old 08-26-2015, 01:36 PM   #16
Flybob's Avatar
In order to keep prices low and profits high, almost every RV made today is right at the limit of the key parameters (axle, wheels, tires, frame,hitch weight) when in normal use. Any major modification that changes any of the key limiting factors is asking for trouble ( failure and potential legal liability). If you want an RV capable of doing something specific, buy one designed for that purpose , your experience will be much more enjoyable.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 08-26-2015, 02:56 PM   #17
I want to put an inflatable raft on my truck-bed rails; it's a pretty standard setup in my area. It would hang 6 1/2 feet off the back. I'm guessing the space between the camper and the truck standard is about 3 1/2 ft, so I would extend it 4 feet to make room for the raft. No toys or extra weight would go on the tongue. This is an idea I came up with instead of pulling the very lightweight trailer with raft (500lbs?) on a stinger hitch, that was deemed a bad idea.
bob2 is offline   Reply With Quote
Old 08-27-2015, 03:48 PM   #18
What about putting a "Ladder Rack" on the Bed Rails, and carrying your Raft atop that (basically like an Industrial-Strength Car-top Carrier)?? Think like folks with Kayaks or Canoes...
At 500lbs, lifting it up would be a b%tch - but you could mount a small Winch at the Front Rail and a Roller (slider?) at the Back Rail.
Pup: '11 HW-296
TV: '09 RAM 1500 Hemi 4x4 CC
seigell is offline   Reply With Quote
Old 08-27-2015, 04:32 PM   #19
That's an idea. it's not 500, I was guessing 500 with the raft+trailer (original idea). The raft+accessories setup is probably 250 (so 500 was probably under for raft+trailer). It is a large and heavy thing though, and usually loaded from akward locations so that would be a long ways up to raise it. Thanks!
towing
