Closed Thread
Old 02-07-2016, 01:45 PM   #71
Who Dares, Wins
doc73's Avatar
You do have a 2015 CHEVY 2500 right? I posted a pic from my 2015.5 and the doors SHOULD look the same at least... I am just shocked it is not there. Probably should not (prob not allowed) to leave the factory without one.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline
Old 02-07-2016, 01:47 PM   #72
asquared's Avatar
Originally Posted by BandJCarm View Post
Asquared and Texas Bob..........I have looked where you said yours is. Mine is not there. My door doesn't even look like ASQ's....my sticker is nowhere. I have stood on my head, looked in glove box, looked in owners manual papers, looked on back doors, you name it.
No sticker.
So it's not on the actual door, the door frame, or the glove box. We know it's legally required to be there somewhere. I'm racking my brain for other ideas.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline
Old 02-07-2016, 01:51 PM   #73
Who Dares, Wins
doc73's Avatar
Yes, mines on the "B" post down low... Very low. Not the door.
My build code sticker is in the upper glove box
2015 ChevyHD D-Max
doc73 is offline
Old 02-07-2016, 02:00 PM   #74
BandJCarm's Avatar
Here's the deal. I just went and looked for the 20th time. That's by actual count, not hyperbole. I have the yellow tire capacity chart, and it lists max cargo capacity at 2286.
Manual lists Max trailer weight (17,100 lbs) and GCWR (24,500 lbs). That is the Diesel Supplement Manual. The actual Owner's Manual makes no mention of any specs of any kind, no hard data, for any diesel truck.
I suppose that some day someone will point this out to me and I'll slap my head. But right now, I am 100% sure it is not there, not anywhere.
Build code sticker is in the glove box. Camper "Shell" weight rating is in glove box (one line in sticker). No RAGWR anywhere.
BandJCarm is online now
Old 02-07-2016, 02:01 PM   #75
Who Dares, Wins
doc73's Avatar
Well here's mines from a 2015.5 2500 DM..
Hopefully will give you an idea.
EDIT: Photo removed.. No longer needed!
2015 ChevyHD D-Max
doc73 is offline
Old 02-07-2016, 02:04 PM   #76
BandJCarm's Avatar
Yes thanks. My tires are 20's, but same truck.
Just no clue why it's missing.
I even have original window sticker. No info there, not even MPG rating.
Old 02-07-2016, 02:07 PM   #77
Who Dares, Wins
doc73's Avatar
Anything over the size of a 1500 do not need the MPG sticker, they are exempted... tire loading will be different, but that will be stamped on the rubber. Axles will be the same.
2015 ChevyHD D-Max
doc73 is offline
Old 02-07-2016, 02:16 PM   #78
BandJCarm's Avatar
Here is pic of door, and doorjamb.
ID:	99107   Click image for larger version
Old 02-07-2016, 02:16 PM   #79
I go RV'ing not Camping
jgourlie's Avatar
My truck also didn't have a sticker...are there on any of your stickers a Model #?
That is how I found out my payload....I cross-referenced the model number to gm specs and my payload came up.
Hope that helps,
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
jgourlie is offline
Old 02-07-2016, 02:18 PM   #80
Who Dares, Wins
doc73's Avatar
How about under the Yellow sticker to its right in the picture between the ground and rear door?
2015 ChevyHD D-Max
doc73 is offline
Closed Thread
towing
