Old 09-29-2015, 07:04 AM   #1
Towing camper
I have a 2014 Ram 1500 Quad Cab 5.7 Liter 4x4 with 3.21 gears and 8 speed transmission. I plan on buying a new 24' surveyor which has a dry weight of 5700 lbs roughly. I plan to add a brake controller and possibly air bags. I would like to put a leveling kit and maybe bigger tires on the truck. Anyone see any problems with my set up and mod plans for the truck? Any advice or tips? Thanks in advance.
05dodgedaytona is offline   Reply With Quote
Old 09-29-2015, 07:07 AM   #2
Kenny kustom's Avatar
3.21 gears, towing, bigger tires.
Honestly, I would re gear to 4.10.
2008 F350 CCSB V10
2016 Sabre 36QBOK
2017 Dynamax Isata 4
Old 09-29-2015, 07:25 AM   #3
Georgia Frog Rally 2018
aceinspp's Avatar
What does your manual say about tow ratings. Changing gears not cheap now days. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 09-29-2015, 07:36 AM   #4
Gears are not cheap...
But, increasing tire size will effectively lower your gear ratio.
2008 F350 CCSB V10
2016 Sabre 36QBOK
Old 09-29-2015, 07:42 AM   #5
TURBS's Avatar
You can get gear set's for around $200.00 - $350.00
Install sets for around $130.00
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "27 nights"
Old 09-29-2015, 07:49 AM   #6
Thanks for the replies. I don't want to go to big on tires just want a little more rubber then factory street tires. Want a nice set of all terrains.
Old 09-29-2015, 08:11 AM   #7
AquaMan's Avatar
Your truck will struggle with the small gear ratio and the potentially 6500# trailer, without adding even slightly bigger tires, which will makes things worse.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 09-29-2015, 10:58 AM   #8
Your truck has an 8500# tow capacity. It'll struggle a little, but those 8 speed transmissions are good at keeping the RPM's up and in the power band. My '13 1500 with 3.55 and 6 speed tows my 6850# dry weight TT just fine.
I would strongly suggest not going with larger tires until you re-gear to 3.73 or 4.10.
You can also look in to a DiabloSport tuner with HemiFever tuning to get some more umph while towing. Single best upgrade for the Hemi.
2013 Ram 1500 Laramie 5.7
2015 Flagstaff 27VRL
Riccochet is offline   Reply With Quote
Old 09-29-2015, 11:03 AM   #9
3.21 is not ideal, but you should be OK with a good WDH (not the friction type). You should be able to get level while towing with the WDH properly adjusted.
I have a longer, heavier TT, check my sig for specs.
2012 Ford F-150 3.7L V6 -- SOLD
2007 Rockwood 1640 LTD Popup -- SOLD
2004 Bantam 19 HTT -- SOLD
2015 RAM 1500 5.7L V8
2015 Coachmen Freedom Express 292BHDS
Loraura is offline   Reply With Quote
Old 09-29-2015, 11:05 AM   #10
Flybob's Avatar
When looking at bigger tires, be sure to consider hitch height especially if using air bags. If the rcvr is too high, you may have trouble finding a drop bar for your WDH to get the ball to the correct height
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
camper, towing
