Old 09-18-2012, 03:01 PM   #1
Towing Capacity
I have a GMC Sierra 1500 w/ 6.2L engine; 143.5" wheelbase; Max Trailer Weight = 10,400 lbs. The SV305 show a GVWR of 10,989 lbs. My GVWR is 7,300 lbs. Do I have enough truck for this model if I take care not to load the trailer to its max capacity?
Dennis Asher is offline   Reply With Quote
Old 09-18-2012, 03:09 PM   #2
Missing Link
cyclepuck's Avatar
What is the empty weight of that trailer?
2014 Puma 30-DBSS
2014 Ram 2500 Mega Cab 6.4L
cyclepuck is offline   Reply With Quote
Old 09-18-2012, 03:13 PM   #3
7,364 lbs.
Old 09-18-2012, 03:30 PM   #4
AKA Bluebird
dimurrrw's Avatar
Send a message via Yahoo to dimurrrw
Towing Capacity Chart | Vehicle Towing Capacity | GMC
Watch out for the combined weight rating for your truck and do you have a tow package?
dimurrrw is offline   Reply With Quote
Old 09-18-2012, 03:49 PM   #5
Triguy's Avatar
Dennis,
Can I recommend that you use a calculator? You're looking at a long and heavy trailer and a calculator will help you to be thorough and review all of the numbers.
Calculator - Travel Trailer Weight Calculator
You will need some more information which you should have in the TV's manual and possibly the door sticker.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 09-18-2012, 03:58 PM   #6
DnD
DnD's Avatar
You look to be in the same situation I was in when looking at the SV 301. I had a Ram 1500 QC and for me it was cutting it too close when calculating the the payload hit to the 1/2 ton. Between the tongue weight & passengers I was going to be over on GVWR and RAWR. It just seemed to me to be too much effort to try and balance loads and not have the ability to take extra gear or passengers. The other concern given to me was the short wheel base (140" for Ram QC) and pulling a 36' trailer.
As you can see below I upgraded TV instead of taking the chance of issues.
Dan n Dione
TV: 2012 Ram 3500 Laramie CC LB 4x4 DRW
RV: 2013 Crusader 325RES Touring Edition
Days Camped: 2012 (3) 2013 (22)
Next Trip: Mission Bay, CA 6/6 - 6/9
DnD is offline   Reply With Quote
Old 09-18-2012, 04:09 PM   #7
I'd think you'd be OK on tongue weight with a WD hitch setup - no more than 1000 lbs.
Keep your trailer to less than 8500lbs loaded and you should be OK there too. The 6.2l is a strong engine. Don't expect any decent economy though.
With your wheelbase, sway is going to be your biggest issue. So your hitch and sway setup will be your primary concern if you keep the weights in check as I've described.
crasher is offline   Reply With Quote
Old 09-18-2012, 04:49 PM   #8
MtnGuy's Avatar
Dennis, you didn't list the year of your truck, but on more recent models the 10,400 lb tow rating is only for the 3.73 gears, with the heavy duty towing package. Make sure you have both of those options.
That trailer is over 35'......that is 1 long trailer. A vehicle with a longer wheelbase would be better. Regardless, a top notch sway control system will be needed. If you can't justify a Hensley or Propride hitch, a name brand WDH with intergrated sway control should be used.....Equal-i-zer 4 pt., Reese Straight Line Dual Cam, and Blue Ox are a few of the better hitches.
As Richard mentioned, staying under the GCWR is going to be a challenge, as well as the GVWR. The listed empty hitch weight is over 800 lbs, so your "ready to camp" weight is probably going to be well over 1000 lbs. Hang that weight on your hitch, along with empty weight of the truck, plus you and passengers plus camping gear in the bed, and that 7300 lbs. is going to difficult to stay under. I would suggest you go weigh the truck with you in it, add up the weights of the family, add at least a 1000 lbs. for the trailer hitch, and see what your final weight might be. And even if you can keep that weight under 7300 lbs., subtract that from the GCWR and see what your trailer can weigh. That trailer is going to weigh in the 8000 lb. range before adding your camping gear.
Also check the sticker on your receiver hitch to make sure it can handle the predicted tongue weight. Many manufacturers just put enough receiver hitch on their vehicles to handle the maximum towing weight. You receiver hitch might list 10,500 lbs., but sometimes will only rate it at 10% of that for a weight distributed tongue weight. 1050 lbs. might not be enough for that trailer.
Old 09-22-2012, 07:55 AM   #9
Realer's Avatar
The way I look at it, if you need to worry about balancing loads, hitch weight, swaying, wheelbase and all those other calculated weights, your TV is too small! Keep the GVW of the TT at 80% of the TV and everyone on the roads will be safer. Too many people try and sell/buy TT's that just push the limits of the TV too far. Just my 2 cents.
'12 F-250 6.2L
'09 Surveyor SV291
Equal-i-zer WD
Realer is offline   Reply With Quote
Old 09-26-2012, 07:21 PM   #10
Check this site for future reference:
Largo, FL Trailer Hitch - 5th Wheel Hitch - Trailer Parts
Silverado 1500 looking forward to tow rv trailer soon
andrew963 is offline   Reply With Quote
