Old 06-19-2013, 06:49 AM   #11
Dave Lyon's Avatar
Originally Posted by bikendan View Post
with the 5.3, the HD trailering package and the 6 speed trans, you'll have no problem towing that trailer.
Agree with Dan. You'll have no trouble. Herk raises a goood point wrt tires.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is offline   Reply With Quote
Old 06-19-2013, 06:49 AM   #12
That truck should handle the trailer with no problems in any way. When towing I would inflate the truck tires to max on sidewall, get a good wd hitch with sway control or add dual friction sway bars and go.
Heck, a full size car with air shocks could pull it even with 15% tongue wt of 600# and a wd hitch as part of the tongue wt will be transferred to the front.
Old 06-19-2013, 06:59 AM   #13
Fulltime family RVer
Originally Posted by JohnF View Post
It appears the gvrw is 7,000#'s. I weighed the truck this morning and it weighs 5,400 with half a tank of gas. So if I add 400 for driver and passenger, 100 for full fuel, 716 (thats 15% of tt gvwr of 4777) , I'm at 6616 lbs.
Looks good to me. Take a look at OldCoot's post above about tire pressure and a good WDH. And Herk's post about your tire load capacity- if it's squirmy after a trip or two, it might be worth upgrading the truck's tires.
ependydad is online now   Reply With Quote
Old 06-19-2013, 07:01 AM   #14
MtnGuy's Avatar
There is no mention of a towing package, which would include an auxiliary transmission cooler.....a must when towing an conventional upright camper fighting wind resistance.
Also, no mention of the final drive ratio. A higher number (lower ratio) would tow better.
Old 06-19-2013, 07:14 AM   #15
JohnF's Avatar
This looks like an auxiliary transmission cooler...correct? Axle ratio is 3.42:1
Ohio
2016 Cedar Creek 36ckts
2015 Ford F-350
4WD SRW Diesel
JohnF is offline   Reply With Quote
Old 06-19-2013, 07:30 AM   #16
MtnGuy's Avatar
You should be good to go !!
Old 06-19-2013, 07:34 AM   #17
That doesn't seem like a great axle ratio considering the size tires you have. I had a 2002 F-150 4wd with the 5.4L and 17" rims and it did not seem to run anywhere near as well as my 2010 F150 2wd 4.6L with smaller tires and rims. This 4.6L would run away from my old 5.4L. They both have 3.55 rear gear ratio too.
But all that being said, I am sure your truck will tow the trailer just fine.
2014 Sunseeker 2860DS
gmacklem is offline   Reply With Quote
Old 06-19-2013, 08:59 AM   #18
Experienced Newbie
According to the Towing Guide from trailerlife.com
Your truck is rated to tow 9600# with the 3.42 axle.
check page 17, lower right corner at the link provided above.
2011 Silverado CC/SB
2014 Cougar 31SQB
mhartzel is offline   Reply With Quote
Old 06-19-2013, 09:21 AM   #19
Taylorgso's Avatar
Back in the 80's (in days before the internet and forums), I bought our first travel trailer, after having lived in popups for years! We had a Ford E150 van, and bought a 24' Coachmen Cadet trailer. The van had the small 302 V8 engine; the trailer as I recall had a GVWR of somewhere around 5400#. I have no idea what the axle ratio was. I did add a transmission cooler at recommendation of mechanic who saw the new trailer hitch and asked what I was towing! We pulled that camper all over Eastern US and Canada, never had a problem of any kind, and it always SEEMED to handle well!
But I was totally ignorant of weights, towing capacities, fuel and water weights, etc. We generally had the van and the camper full of "stuff" and I'm now sure I was probably overweight by substantial margin. If I were towing the same setup now, what with the Internet, etc., I'd have probably bought a different TV with 4:10 axle and the biggest engine, upgraded the tires, shed a lot of those pounds in the trailer (we always had full FW tank when traveling), taken it to scales (Don't think CAT scales were even in business then), and lose sleep over whether I had everything within specs.
Just goes to show that occasionally, ignorance is not penalized!
Ed (N4RWU) & Becky Taylor
Mistie (Walks 4-down)
Greensboro, NC
Taylorgso is offline   Reply With Quote
Old 06-19-2013, 11:00 PM   #20
Oklahoma Proud
MillerTime's Avatar
3.42 is the lowest ratio you can get without getting the towmax package with the 6.2 that has 3.73 gears available.
Should be good pulling that rig!
Oh and yes that is an axillary tranny cooler that is usually included in the tow package, they will also have a receiver hitch and trailer plug at the rear.
