Old 06-20-2013, 12:56 AM   #21
bikendan's Avatar
Originally Posted by mtnguy View Post
There is no mention of a towing package, which would include an auxiliary transmission cooler.....a must when towing an conventional upright camper fighting wind resistance.
in the first post, in the picture, under "Mechanical", it says HD Trailering Equip., along with Trailering Suspension.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 06-20-2013, 05:49 AM   #22
Herk7769's Avatar
Originally Posted by mhartzel View Post
According to the Towing Guide from trailerlife.com
Your truck is rated to tow 9600# with the 3.42 axle.
check page 17, lower right corner at the link provided above.
There is always a "Caveat" to these ratings and that is "When Properly Equipped." Many options available "for looks" subtract from the tow rating. Fancy wheels and 20 inch tires have a negative impact on tow rating (if memory serves).
HAM CALLSIGN - KC3FFW
Old 01-07-2014, 12:48 PM   #23
JohnF's Avatar
The tires are Eagle LS-2’s. P275/55R20. I called Toyo yesterday and talked with a lady about my tires and towing. She explained that the tires on my truck (original) might be the best for what I want to do. I was asking her that when they wear out if I should go to an LT tire. After much discussion she said in the end she would stay with the P tires and run them to max pressure (45 psi) when towing. If I went to LT’s I would be giving up comfort for peace of mind (which may not be real). She however repeated that my question was the most common asked and they recommend you stay with the manufacture’s original choice on the truck. When I wear these out, I will do more research on the benefits of switching to LT’s if there are any. I have not towed with this vehicle yet to test the P tires.
Ohio
2016 Cedar Creek 36ckts
2015 Ford F-350
4WD SRW Diesel
JohnF is offline   Reply With Quote
Old 01-07-2014, 12:51 PM   #24
JohnF's Avatar
Youroo, our first trip this year will be to the Tadpole rally on the river. I trust I can count on you for emotional support, if needed, with my new TV and it’s tires?
Ohio
2015 Ford F-350
4WD SRW Diesel
