06-18-2013, 08:36 PM
Towing Capacity
In another post I mentioned the upcoming purchase of a friends truck. Today I gathered most of the information I could to check towing capacities and never found those numbers. Attached is an image of the specs. Can I assume this 2011 Sierra 1500 4wd extended cab pickup has what I need to pull my 4000 lb
21FBRS TT?
Ohio
2016 Cedar Creek 36ckts
2015 Ford F-350
4WD SRW Diesel
06-18-2013, 08:51 PM
Yes imho there shouldnt be an issue towing a 4000# trailer with a 4x4 with a 5.3 liter. I towed our 5900 lb trailer (empty) with a 2wd dodge ram with a 4.7 liter v6 without issues. I now use a dodge ram 4x4 with a 5.7 hemi. Both trucks were company supplied.
Kevin and Joanne
06 wildwood 27le fbss
08 dodge ram 4x4 5.7 quad cab
07 kawasaki brute force 650i
06-18-2013, 09:07 PM
Always Learning
You specifically want to find the two stickers on the doorjamb that tell you:
#1- GVWR and GAWR for front and read
#2 - the amount of pounds the truck can carry in the form of passengers and cargo
Usually with 1/2-ton trucks, you run out of payload (#2) capacity with driver, passengers, pets and stuff in the truck bed long before you hit your maximum towing capacity (only possible if it's a stock truck and *nothing* but a 150-pound driver in it).
06-18-2013, 09:10 PM
Always Learning
Most likely the answer is yes unless you have a big family or carry a lot in the truck bed. Here's how to find out:
What can I tow?
06-18-2013, 09:18 PM
If you go to the GMC web site you can go to a section which allows you to pick your truck size (1500, 2500, etc) and then your configuration (extended cab, crew cab, etc.) and then your engine choices. You can then do a comparison of two or three. It will give you all the towing specs. you need (pin/load, gross trailer capacity, etc.)
2012 Sabre 250RLUD
2011 GMC 1500 Sierra
Max Tow, 6.2, 3.73
Rod, Debbe 1 spoiled Chihuahua and Becky the cat
06-19-2013, 02:09 AM
Here is that sticker.
Ohio
2015 Ford F-350
4WD SRW Diesel
06-19-2013, 02:58 AM
with the 5.3, the HD trailering package and the 6 speed trans, you'll have no problem towing that trailer.
06-19-2013, 06:07 AM
I would imagine that truck is rated well enough to tow the 21FBRS. I have the 21FBRS and am towing it with a Ford F-150 2wd supercab with the 4.6L v8 and it does just find. Can be tough to pick up speed up hill, but that goes with most towing I think.
2021 Micro Lite 25FKBS
2021 Ford F-250 XLT CCSB 4wd w/ 6.2l and 6 sp. transmission, 3.73 locking axle
06-19-2013, 06:11 AM
Check your tires.
I think they might be great for "show" but not for "tow"
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
06-19-2013, 06:20 AM
It appears the gvrw is 7,000#'s. I weighed the truck this morning and it weighs 5,400 with half a tank of gas. So if I add 400 for driver and passenger, 100 for full fuel, 716 (thats 15% of tt gvwr of 4777) , I'm at 6616 lbs.
Ohio
2015 Ford F-350
4WD SRW Diesel
06-19-2013, 06:49 AM
Agree with Dan. You'll have no trouble. Herk raises a goood point wrt tires.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
That truck should handle the trailer with no problems in any way. When towing I would inflate the truck tires to max on sidewall, get a good wd hitch with sway control or add dual friction sway bars and go.
Heck, a full size car with air shocks could pull it even with 15% tongue wt of 600# and a wd hitch as part of the tongue wt will be transferred to the front.
06-19-2013, 06:59 AM
Always Learning
Looks good to me. Take a look at OldCoot's post above about tire pressure and a good WDH. And Herk's post about your tire load capacity- if it's squirmy after a trip or two, it might be worth upgrading the truck's tires.
06-19-2013, 07:01 AM
There is no mention of a towing package, which would include an auxiliary transmission cooler.....a must when towing an conventional upright camper fighting wind resistance.
Also, no mention of the final drive ratio. A higher number (lower ratio) would tow better.
06-19-2013, 07:14 AM
This looks like an auxiliary transmission cooler...correct? Axle ratio is 3.42:1
Ohio
2015 Ford F-350
4WD SRW Diesel
06-19-2013, 07:30 AM
You should be good to go !!
06-19-2013, 07:34 AM
That doesn't seem like a great axle ratio considering the size tires you have. I had a 2002 F-150 4wd with the 5.4L and 17" rims and it did not seem to run anywhere near as well as my 2010 F150 2wd 4.6L with smaller tires and rims. This 4.6L would run away from my old 5.4L. They both have 3.55 rear gear ratio too.
But all that being said, I am sure your truck will tow the trailer just fine.
06-19-2013, 08:59 AM
Experienced Newbie
According to the Towing Guide from trailerlife.com
Your truck is rated to tow 9600# with the 3.42 axle.
check page 17, lower right corner at the link provided above.
2011 Silverado CC/SB
2014 Cougar 31SQB
06-19-2013, 09:21 AM
Back in the 80's (in days before the internet and forums), I bought our first travel trailer, after having lived in popups for years! We had a Ford E150 van, and bought a 24' Coachmen Cadet trailer. The van had the small 302 V8 engine; the trailer as I recall had a GVWR of somewhere around 5400#. I have no idea what the axle ratio was. I did add a transmission cooler at recommendation of mechanic who saw the new trailer hitch and asked what I was towing! We pulled that camper all over Eastern US and Canada, never had a problem of any kind, and it always SEEMED to handle well!
But I was totally ignorant of weights, towing capacities, fuel and water weights, etc. We generally had the van and the camper full of "stuff" and I'm now sure I was probably overweight by substantial margin. If I were towing the same setup now, what with the Internet, etc., I'd have probably bought a different TV with 4:10 axle and the biggest engine, upgraded the tires, shed a lot of those pounds in the trailer (we always had full FW tank when traveling), taken it to scales (Don't think CAT scales were even in business then), and lose sleep over whether I had everything within specs.
Just goes to show that occasionally, ignorance is not penalized!
Ed (N4RWU) & Becky Taylor
Mistie (Walks 4-down)
Greensboro, NC
06-19-2013, 11:00 PM
Oklahoma Proud
3.42 is the lowest ratio you can get without getting the towmax package with the 6.2 that has 3.73 gears available.
Should be good pulling that rig!
Oh and yes that is an axillary tranny cooler that is usually included in the tow package, they will also have a receiver hitch and trailer plug at the rear.
