Old 06-18-2013, 08:36 PM   #1
JohnF's Avatar
Towing Capacity
In another post I mentioned the upcoming purchase of a friends truck. Today I gathered most of the information I could to check towing capacities and never found those numbers. Attached is an image of the specs. Can I assume this 2011 Sierra 1500 4wd extended cab pickup has what I need to pull my 4000 lb
21FBRS TT?
Ohio
2016 Cedar Creek 36ckts
2015 Ford F-350
4WD SRW Diesel
JohnF is offline   Reply With Quote
Old 06-18-2013, 08:51 PM   #2
Wildwood1's Avatar
Yes imho there shouldnt be an issue towing a 4000# trailer with a 4x4 with a 5.3 liter. I towed our 5900 lb trailer (empty) with a 2wd dodge ram with a 4.7 liter v6 without issues. I now use a dodge ram 4x4 with a 5.7 hemi. Both trucks were company supplied.
Kevin and Joanne
06 wildwood 27le fbss
08 dodge ram 4x4 5.7 quad cab
07 kawasaki brute force 650i
Wildwood1 is offline   Reply With Quote
Old 06-18-2013, 09:07 PM   #3
Fulltime family RVer
You specifically want to find the two stickers on the doorjamb that tell you:
#1- GVWR and GAWR for front and read
#2 - the amount of pounds the truck can carry in the form of passengers and cargo
Usually with 1/2-ton trucks, you run out of payload (#2) capacity with driver, passengers, pets and stuff in the truck bed long before you hit your maximum towing capacity (only possible if it's a stock truck and *nothing* but a 150-pound driver in it).
ependydad is online now   Reply With Quote
Old 06-18-2013, 09:10 PM   #4
Most likely the answer is yes unless you have a big family or carry a lot in the truck bed. Here's how to find out:
What can I tow?
Old 06-18-2013, 09:18 PM   #5
If you go to the GMC web site you can go to a section which allows you to pick your truck size (1500, 2500, etc) and then your configuration (extended cab, crew cab, etc.) and then your engine choices. You can then do a comparison of two or three. It will give you all the towing specs. you need (pin/load, gross trailer capacity, etc.)
2012 Sabre 250RLUD
2011 GMC 1500 Sierra
Max Tow, 6.2, 3.73
Rod, Debbe 1 spoiled Chihuahua and Becky the cat
1Texan is offline   Reply With Quote
Old 06-19-2013, 02:09 AM   #6
JohnF's Avatar
Here is that sticker.
Ohio
2015 Ford F-350
4WD SRW Diesel
Old 06-19-2013, 02:58 AM   #7
bikendan's Avatar
with the 5.3, the HD trailering package and the 6 speed trans, you'll have no problem towing that trailer.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 06-19-2013, 06:07 AM   #8
I would imagine that truck is rated well enough to tow the 21FBRS. I have the 21FBRS and am towing it with a Ford F-150 2wd supercab with the 4.6L v8 and it does just find. Can be tough to pick up speed up hill, but that goes with most towing I think.
2014 Sunseeker 2860DS
gmacklem is offline   Reply With Quote
Old 06-19-2013, 06:11 AM   #9
Herk7769's Avatar
Check your tires.
I think they might be great for "show" but not for "tow"
HAM CALLSIGN - KC3FFW
Old 06-19-2013, 06:20 AM   #10
JohnF's Avatar
It appears the gvrw is 7,000#'s. I weighed the truck this morning and it weighs 5,400 with half a tank of gas. So if I add 400 for driver and passenger, 100 for full fuel, 716 (thats 15% of tt gvwr of 4777) , I'm at 6616 lbs.
Ohio
2015 Ford F-350
4WD SRW Diesel
