03-14-2014, 04:53 PM
Towing Capacity
Can someone explain WHY two trucks with the same motor size, transmission gearing, and general dimensions will not tow the same amount? I was looking at the difference between the early year 2007 Chevrolet 1500 extra cab 4x4 with a 5.3l motor and a 3:42 rear end compared to the same truck as a 2009. Same truck but different body styles as the early 07 was the old styling.
2007: 5.3 liter engine with 3:42 rear end tows 7500 lbs
2009: 5.3 liter engine with 3:42 rear end tows 5900 lbs
This makes no sense unless the frame is different or they have either overestimated or underestimated one or the other. Can anyone explain why this is?
My camper weighs 5700 lbs so you can see my concern...or wonder which truck to buy...
03-14-2014, 05:15 PM
2 completely different trucks from frame up. The only thing in common are the names.
Sent from my LG-LS720 using Forest River Forums mobile app
2006 Roo 23B hybrid
2006 Ford F150 4.6L
03-14-2014, 05:17 PM
with that gear ratio you should be able to tow #9600. I'd have the dealer to a vin check on both of them and have them validate the rear gear ratio
2013 Prime Time Tracer 3200BHT
2016 Chevy 3500 CC, DRW (aka: bigbootyjudy)
Ribs in the smoker and Whiskey in hand
03-14-2014, 06:07 PM
the reason why is that the 2007 had the 4 speed trans and the 2009 had the new 6 speed trans.
makes a big difference with the 3.42 rear end.
03-14-2014, 06:27 PM
Was the 2009 the first year of 6 speed transmission?
03-14-2014, 06:34 PM
so shouldn't the 09 have more capacity, not less?
David & Lynn 2014 Coachmen Chaparral Signature 327 RLKS 2016 Ford F350 Lariat CC Dually
03-14-2014, 06:36 PM
Short or long bed?
03-14-2014, 06:46 PM
i think the amounts are backwards.
03-14-2014, 07:11 PM
I have an 09 Silverado 5.3l 3.42 rearend and Heavy duty tow package and am rated for 9500lbs
03-14-2014, 10:22 PM
Regular bed. Standard on both. I called Chevrolet and the numbers they gave me were what the books say...09 5900 lbs. 07 7500 lbs
03-15-2014, 03:23 AM
Engineer of Crazy Train
Does the 09 have the cooling package? Looking at the database, that makes a huge difference.
Sent from my Samsung Galaxy Note 2 using the FRF mobile app.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183 (SOLD due to 2 years off work)
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 - 18
Come read my Camping Blogs
03-17-2014, 04:08 PM
You are only stating 2-3 parameters. What about transmission gearing (not just axle ratios). HD towing package?
03-17-2014, 04:38 PM
The book has all models in it, I'd go have the dealer run your vin to be sure on what you have in your truck. They can give you the exact specs of your truck.
Though when I bought mine, the salesguy told me #9600, but I still had them run the vin to be sure and they gave me the exact specs and I'm able to pull #9600
03-17-2014, 05:04 PM
Here's a link to the 2009 Silverado Owners Manual.
http://www.chevrolet.com/content/dam...ado_owners.pdf
The towing info starts on page 4-52. There are 99 different permutations of Silverado 1500's to chose from. If you don't have the HD cooling, then I think the 5900 they told you is correct.
Good luck.
2011 Traverse LT, 3.6L, FWD
03-18-2014, 06:51 PM
I think I will stick with the seven model. It tows more and seems to be built stronger...
03-18-2014, 06:54 PM
Check the 2010, I remember 1 year had a chump rating but others were better.
2007 may or may not be the same as 2010, 2007 was a GMT-800 and GMT-900.
10 CTS AWD Wagon
10 BMW X5 35D
08 Mercedes GL320
08 Outback 21RS
