Old 03-03-2013, 09:18 PM   #1
Towing capacity of a 2012 Chevy.
2012 Chevy cc z71 4x4 5.3 liter and the 3.42 gear ratio. Max trailing as I read it is 9500.
Misc Info.
Curb weight - 5288, payload - 1712, gvwr -7000, gcwr -15000, front gross axle weight rating 3950, rear gross axle weight ratio - 3950
According to my research the max travel trailer loaded I want to pull is about .80 percent of 9,500 or 7,600 lbs. can I get a second opinion on this from you more experienced guys?
Travis
LSUTiger is offline   Reply With Quote
Old 03-03-2013, 09:36 PM   #2
wyo700's Avatar
That's sounds right from what I had read also. Someone will probably come on and tell you eXactly. If you do a little research I am sure it can be easily found.
2012 Sandstorm 203slc
2013 Toyota Tundra
Eqil-l-izer hitch,Prodigy P3
2014 Honda Pioneer 700-4
2004 Yamaha Grizzly 660
wyo700 is offline   Reply With Quote
Old 03-03-2013, 10:31 PM   #3
bikendan's Avatar
you don't mention if you have the HD tow package. i'm sure that 9500 number requires having that.
i think you're wise using the 80% formula.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 03-03-2013, 10:39 PM   #4
Iggy's Avatar
Misc Info.
Travis
Check this link
2012 Chevy Colorado | Midsize Pickup Truck | Chevrolet.com
Go down to trailer selector and open up the screen .
Pull the weight slider to 10,000 lbs and it shows what will pull that weight
Iggy is online now   Reply With Quote
Old 03-03-2013, 11:28 PM   #5
Missing Link
cyclepuck's Avatar
Yes 9500lbs if equipped with hd trailering and hd cooling pkg. I pull a tt just over 8k with mine and it does well I sure wouldn't want to pull in any mountains with it.
2014 Puma 30-DBSS
2014 Ram 2500 Mega Cab 6.4L
cyclepuck is online now   Reply With Quote
Old 03-04-2013, 07:23 AM   #6
Update to thread
Yes the truck has the trailering package as well as the heavy duty cooling!
Old 03-04-2013, 08:13 AM   #7
camper1999's Avatar
That sounds about right. IF you are only going to tow to close/local campgrounds you can probably push that number a little.
2011 GMC 2500HD Diesel
Old 03-04-2013, 08:52 AM   #8
daydreaming about camping
jeeplj8's Avatar
Misc Info.
Travis
Going with your numbers above, start with your curb weight, then add passengers and gear to the truck. With a crew cab, figure two adults and two kids, plus just their gear (ipods, jackets snacks and such at 500 lbs. That leaves you with 1212 payload rating. and your GCVWR would be 13.4 so under your posted 15 figure.
A 7600 lb trailer with a 15% tongue weight (the maximum you want in tongue weight) would be 1140. You would be under your payload rating by a few pounds. With some skill at loading the trailer, you could cut that tongue weight down a bit.
So at the weight you posted, yes you would be under your max weight ratings.
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
Old 03-04-2013, 08:53 AM   #9
WolfWhistle's Avatar
Misc Info.
Travis
Travis, my Chevy sounds very similar to yours; it has all the HD towing options (coolers, synthetic lubricants, etc.), short bed crew, LC9 (E85) motor (326HP), stock size wheels and tires, 6 speed Allison, plus 3:73 gears (!), 326HP and 348lb/ft torque. The information I have is that with all these it will pull 9500#, but your maximum calculated at 7600# has some merit. This is of course, with a properly setup WDH and weights properly distributed. This 7600# number is possible, but slightly high IMHO. It is a matter of torque and power range of this engine. It is possible to overload that 3950# rated rear axle if you put anything heavy in the bed.
The 21RR I pull, is maybe 6500# going camping, with 750# on the tongue; it is ALL the trailer I would ever pull in the low hills with this truck. This would be with a bike, but no water. I would recommend putting nothing in the bed. What I don't like about even pulling with my truck (the 21RR) is that you must keep the RPM above 2500 to 3500 RPMs. It will many times be in as low as 3rd gear, rarely for sure, but much of the time in 4th for the slightest grade; never ever past 5th. I have been on 16% grade and it would barely pull 2nd gear at 22-25MPH at near wide open throttle. This would be at maybe 3000 RPM... It will cook the transmission doing this. The ambient temp was around 45 degrees and the tranny hit 290 degrees. I backed off when I saw this. So, another point is you can't be in any hurry.
I don't use tow/haul, never use cruise control; rather prefer to manually shift the Allison. As you know, if you manually select 4th it won't shift to 5th. Traveling and camping is supposed to be fun... the 5.3L simply is not fun pulling even 6000#. It has enough HP, so, if you wind the heck out of it, it will pull. But, again this is not fun for me.
I have pulled for 15,000 miles with this combination. I have a long history of pulling.
So, IMHO our pick'em'ups will pleasantly pull up to 5500#, again IMHO it takes a 3/4 ton past that, but at 8000# and up, you really need a diesel. Also, my truck is rated to get 21MPG highway... the best it has ever gotten is 18.1 MPG Interstate, 65 MPH, with cruise, flat highway; empty truck (tonneau cover only, which should have helped economy); no trailer. While pulling the 21RR at 60 MPH, it averages less than 10MPG (9.4 to 10.4). Hope this helps.
I am not sure how to edit this but 2012 I camped 163 days, but none so far this year... yet. Ready to go!! I have washed and waxed "the Wild One" however.
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 03-04-2013, 09:37 AM   #10
acadianbob's Avatar
I would double check your trailer weight capacity. A 3.42 rear gear is unlikely to be 9000+ IMO.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
