Old 05-19-2019, 10:30 PM   #1
Towing Chevy Colorado or GMC Canyon 4 Down
I decided that I wanted a small truck to tow 4 wheels down and Motorhome said both the Chevy Colorado and the GMC Canyon were towable. It said they had to be “4WD WITH A NEUTRAL and a 4L SETTING”. I was thrilled until I started looking at 30 trucks and NONE had a Neutral setting for the transfer case. HELP! Am I missing something or is it just very rare to find a towable small truck with a N setting. Have any of you gone thru this? Is there a fix for this?
fdwarren is offline   Reply With Quote
Old 05-19-2019, 10:44 PM   #2
DieselDrax's Avatar
The Colorado and Canyon do have a neutral setting with the transfer case, on the newer models it’s on the 4WD knob all the way to the right and there is a sequence to follow to switch to neutral. See attached pic.
2017 GMC Canyon - CCLB, 4x4, 2.8L Duramax, ARE Z-series shell
2013 Shamrock 21SS
DieselDrax is online now   Reply With Quote
Old 05-21-2019, 08:54 PM   #3
I found one Colorado that did not work and of course that was the one I was thinking about buying. I am now looking at a GMC Canyon all terrain 4WD and it works just like that. Thanks!
Old 05-21-2019, 08:54 PM   #4
Retired Army Paratrooper
MasterBlaster's Avatar
Most all new model 4x4 have a Neutral, you just probably don't see it on the knob because it lights up when you engage it.
Dennis & Zoleta
Retired US Army
Force 37BHHD
MasterBlaster is offline   Reply With Quote
Old 05-22-2019, 09:10 AM   #5
Since the transfer case is selected electronically, does the ignition have to be on when flat towing it?
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
upflying is offline   Reply With Quote
Old 05-22-2019, 09:31 AM   #6
DieselDrax's Avatar
Not for the transfer case, no. The key does need to be left in the ACC position to prevent the steering wheel lock from engaging, though, and the battery should be disconnected.
2013 Shamrock 21SS
towing
