Old 06-14-2016, 03:41 PM   #11
I use tow/haul and cruise control all the time with od engaged.
2003 GMC 2500 HD 8.1 & ALLISION TRANSMISSION
2000 SIERRA 30 ft FKSS
hondo is offline   Reply With Quote
Old 06-14-2016, 04:21 PM   #12
RudysWorld's Avatar
Check your owners manual, some vehicles lock out overdrive and some are Tow/Haul which minimize shifting engage engine brake on downhill situations. They are totally different and are used in different situations for different reasons.
Rudy - 10 year old long haired dachshund, RIP
2011 Georgetown 350TS
2013 Chevrolet Equinox toad
RudysWorld is offline   Reply With Quote
Old 06-14-2016, 04:21 PM   #13
m2kamp's Avatar
Tow/Haul button pressed
Manually lock out 7th and 8th
Cruise set to 65 mph
RPM around 2100 in 6th
10-12 MPG
Rarely shifts.
If I don't manually set 6th as max gear it will happily go to 8th even in tow/haul mode and shift frequently between 6th, 7th and 8th and the "ECO" light pops on lol
2015 Wildwood 26TBSS Equalizer 4pt 10k
2018 Ram 1500 CC 5.7L 4x4 3.92 LSD
2017 Ram 1500 CC 3.6L 4x2 3.55
m2kamp is offline   Reply With Quote
Old 06-14-2016, 04:41 PM   #14
Tow/Haul on, cruise set for 60, runs about 1500rpm, 11mpg on flat/hilly. Always leave 6th gear in place. Mtns more manual mode. F250, diesel.
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
Old 06-14-2016, 04:50 PM   #15
Tow Haul Mode
In my owners manual on my dodge Ram 1500 it says to only use tow Haul when taking off or in hilly terrain My TT only weighs 4750 I never use Tow Haul
But I do use cruise Control getting 10 to 11 MPG
jec9017 is offline   Reply With Quote
Old 06-14-2016, 04:54 PM   #16
I have a 12 Silverado 3500 SRW diesel, I run in tow/haul, set the exhaust brake and once truck gets to 63 I set the cruise. Up a steep mountain I set the speed lower. I just keep truck between the lines. I can hardly wait until self driving vehicles come out
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 06-14-2016, 05:19 PM   #17
NMWildcat's Avatar
We started out using tow/haul but not cruise. Later when we got used to our truck we use cruise all the time except steep downhills when we use manual mode.
You should do whatever you and your tow vehicle are comfortable with.
NMWildcat is online now   Reply With Quote
Old 06-14-2016, 05:43 PM   #18
Kenny kustom's Avatar
Originally Posted by MKClark View Post
First I put it in the trailer/haul mode. Then set cruise at 65 mph and let the truck do it's thing. Does great in the rolling hills of Texas.
________________
MK Clark
2014 Chevy 1/2 ton 5.3/3.42
Exactly the same here.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 06-14-2016, 05:44 PM   #19
I have a Sierra with the 6.0 liter Vortec. I usually use tow mode but if the terrain is reasonably flat for an extend period I take tow mode off. It drops my rpm to 1850 (at 60 mph) from just over 2000. I'm assuming there would be some economy involved there.
I never engage cruise control. Too much shifting and therefore harder on the tranny.
Larry Cole is offline   Reply With Quote
Old 06-14-2016, 05:49 PM   #20
Blackhat6mike's Avatar
We have a Chevy 2500HD Duramax/Allison pulling 10,000+ lb TT. I always leave it in DR with the exhaust brake turned on and the cruise control on. The Allison tranny figures out what it needs. In the mountains, the cruise control will do all the gearing down necessary for the downhill runs. If it goes above 3,800 rpms, I might add a little breaking [exhaust] but rarely had to. To us, the Allison tranny is worth everything in towing.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
towing
