Old 06-14-2016, 10:10 PM   #21
Oklahoma Proud
MillerTime's Avatar
I use to never tow with cruise, but after catching myself going 79-80mph, (on a 75 mph turnpike, but staying with traffic) i had to start using it to keep my speeds down. Lol!!
Sometimes i wish i could set a limiter on my speed! My truck might actually have that option, but i haven't checked.
This is on a Gmc, Duramax 3500hd. Tow/haul always on and always left in drive .
Old 06-14-2016, 10:13 PM   #22
CaptnJohn's Avatar
F250 diesel ~~~ set tow/haul, engine brake, and cruise at 65. Usually around 1600 rpm and 11.3 - 12.1 mpg. Down a steep grade just lower the speed control to a safe number.
2017 Montana HC 370BR
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
CaptnJohn is online now   Reply With Quote
Old 06-14-2016, 10:29 PM   #23
I concur, the cruise control will actually take over going downhill and do the downshifting to maintain the set speed. Just make sure you set the speed lower as the cruise control overshoots before it slows to the set speed.
Personally, I will let the cruise control maintain speeds on hilly roads but not in the mtns, I want to be in charge there
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
dalford is online now   Reply With Quote
Old 06-14-2016, 10:36 PM   #24
CaptnJohn's Avatar
2 lane mtn roads means no cruise but interstate mountains let the cruise handle it, just set safe speed.
2016 F350 diesel
Old 06-14-2016, 11:58 PM   #25
Originally Posted by MKClark View Post
First I put it in the trailer/haul mode. Then set cruise at 65 mph and let the truck do it's thing. Does great in the rolling hills of Texas.
________________
MK Clark
2014 Chevy 1/2 ton 5.3/3.42
x2. Just drove 950 miles like this. Worked perfectly. I also keep cruise in when going downhill, and the truck maintains a constant speed.
Sent from my SD4930UR using Tapatalk
2016 Salem Cruise Lite 261bhxl
Ram 1500 5.7l Hemi Crew Cab 4wd
gspot01 is offline   Reply With Quote
Old 06-15-2016, 08:46 AM   #26
I'll use cruise or I seem to always creep over faster than I want to go, between 63 and 65. If I don't use the cruise it seems I always end up creeping up to 70. The truck pulls very smoothly and it just happens.
Dwayne and Susan
Jiro and Phoebe-4 legged family members
Mike and Dana - Traveling buddies
2016 Ford F350 XLT 6.7 Powerstroke DRW 4X4
2016 Brookstone 395RL
dwayneb236 is offline   Reply With Quote
Old 06-15-2016, 08:51 AM   #27
Tow/haul on, 6th gear locked out. Cruise when things are quiet in the interstate. '13 Duramax/Allison
Springerdad is offline   Reply With Quote
Old 06-15-2016, 09:24 AM   #28
Read the tv manual. Many potential decision points. Today's electronic transmissions aren't what (I/we) grew up with.
My Tundra: tow haul engaged, lsd & anti sway disengaged, no cruise control. 60mph, 10.2 mpg over 1100 miles (NC to AL and back - over the "mtns" - US highway and Interstate mix) - 12,800 lbs combined weight
Retired U.S. Coast Guard Mustang
Presently a librarian @ Duke
2016251RKS is offline   Reply With Quote
Old 06-15-2016, 12:18 PM   #29
rvb
my truck (2010 f150) wont let me lock out o/d gears. all I can do is put it into tow/haul. I wish I could lock out the o/d gears, because then I could use cruise control. it seems 65ish mph in 6th is right at that point it wants to shift a lot with even a hint of grade, so if I don't use cruise, I can better reduce the shifting. later years added 'select shift' which would sure be nice to have!
-rvb
Ryan V. B.
2017 FR Wildwood XLite 195BH
2010 F-150 4x4, 4.6L
rvb is offline   Reply With Quote
Old 06-15-2016, 12:31 PM   #30
I always use the TH mode when towing the TT. I do use the cruise when traveling on the interstate. I set it at 68 mph.
dnjsellars is offline   Reply With Quote
towing
