Old 06-15-2016, 05:07 PM   #31
I tow with 7.3 powerstroke in with OD on and on cruise at 65 mph. Get 11.3 mpg.
lazyjj is offline   Reply With Quote
Old 06-15-2016, 07:08 PM   #32
Mat
Each vehicle are different... mine don't have towing mode but manufacturer recommend towing with Overdrive off, your owners manual will tell you. As for cruise control I put it on as often as possible and when it's safe to do so, having a heavy foot, cruise control is a must for me!
Mat is offline   Reply With Quote
Old 06-15-2016, 07:19 PM   #33
dgibbs1955
dgibbs1955's Avatar
Towing cruise and O.D
I just got done driving from Fort Worth to Iowa City in one shot....15 hours and 855 miles later...I used the T/H and set the cruise at 65-68 and the first half I kept it in 6th and got around 11mph. The second half I used the overdrive and ended up with 9 mph. Sometimes hard to judge with so many rolling hills through OK, MO and IA. It was great all the time in KS.
I forgot to mention that I have a 2012 Ram 3500 SRW 6.7, 3.73 that has been decluttered and chipped with 5 programs.
2012 Dodge 3500 Cummins Crew Cab 4X4, "Decluttered" and Tuned/2013 Forrest River Viper XLR 390V10 Toy Hauler/2012 Harley Davidson Ultra Glide CVO.
Full time RVer.
dgibbs1955 is offline   Reply With Quote
Old 06-15-2016, 07:23 PM   #34
Blackhat6mike's Avatar
I have found that my Allison tranny knows a lot more about what it needs than I do. With the cruise set at 63-65, exhaust brake on and in regular drive, it rarely downshifts except in the mountains or hilly regions. If it doesn't need a lower gear, it doesn't downshift. Why drive around in 5th when 6th works just fine? Gas mileage between 11.5 and 13.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 06-15-2016, 09:14 PM   #35
Kenny kustom's Avatar
Sometimes I force it into 6th, to see if it will hold... But usually it will stay in 5th.
One thing I did notice with one of my other trucks.. There was a big load difference bt 5&6.
Sure the rpm was higher in 5th, but the load on the engine was much less. Which would equal higher mpg.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 06-15-2016, 09:21 PM   #36
muddyrode's Avatar
Yes when towing turn on the tow/haul mode set cruise at 63-64 and enjoy the drive
2016 SANDPIPER 35ROK
2013 Silverado Duramax 3500HD DRW LB
Stop worrying about the potholes in the road and enjoy the journey
muddyrode is offline   Reply With Quote
Old 06-15-2016, 09:34 PM   #37
W5CI's Avatar
[QUOTE=muddyrode;1229112]Yes when towing turn on the tow/haul mode set cruise at 63-64 and enjoy the drive[/QUOTE
X2
Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2017 Days Camping 77
2018 Days Camping 3
W5CI is online now   Reply With Quote
Old 06-16-2016, 06:27 AM   #38
"All in Good Time"
vnichols's Avatar
I use tow/haul, Max exhaust break & cruise all the time towing my 12k loaded 5er with Ram 2500 mega cab CTD. Just returned from a trip to Kentucky from Charlotte and the truck performed very well through mountains across i40 and up i75. Set it on 60 to 62 mph and the computer keeps it on speed. Even on those steep down hill grades it kept it on set speed to within 3-5 mph.
Vince & Ulli
2016 Wildcat 327CK
2014 Ram 2500 Mega Cab 6.7 CTD 4x4
vnichols is online now   Reply With Quote
Old 06-16-2016, 06:34 AM   #39
Dave Lyon's Avatar
I use cruise occasionally (not often) only on flat stretches. As others have mentioned, I put it in tow/haul mode and then hit cruise.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is offline   Reply With Quote
Old 06-16-2016, 06:59 AM   #40
Butch Wilson's Avatar
I have a light trailer 4,000 lbs and a 2013 Chevy 1500 Z71 with tow package. Yes I use cruise on the interstates unless the traffic is really heavy. Unless I am in the mountains or really hilly country I do not use tow/haul . I also turn off Chevy's stabilization control it tends to over-react in my opinion. (i decided cruise was a good idea when I found myself towing our old pop-up at 90 miles an hour in a Wyoming 80 mph zone !)
Butch Wilson is offline   Reply With Quote
towing
