Old 11-18-2015, 10:17 AM   #71
CWSWine's Avatar
I keep hearing how great these little engines are and how the out preform V8s and even some say they tow like diesel so why don't they put them in HD trucks? They announced the engine line for the 2017 HD still no EB. They did announce that there will be a V10 option in 2017.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 11-18-2015, 10:26 AM   #72
CWSWine's Avatar
Originally Posted by jaherbst View Post
2013 F150 EB here. Towing 7500#. 50,000 miles with 22,000 towing. No problems, Love that EcoBoost!
It also fits in a garage at home. A plus for me.
Jack
My F350 1 ton is shorter than F150 Crew Cab and fits fine in my garage. Matter A Fact the F150 Crew Cab won't fit in my garage.
Old 11-18-2015, 10:29 AM   #73
Because Ford doesn't consider the EB as a "heavy duty" motor.
Its the same reason GM still uses the 6.0 iron block Vortec in their HD trucks and not the 6.2 aluminum block Ecotec.
It's all good until the EPA sticks its nose a little deeper into HD trucks, and that day is coming.
You also get more with heavy duty trucks than just heavy duty engines such as heavier frames, brakes, drive line components, gear, etc. Its not all about HP, torque, and fuel mileage but for some reason that is the only things most people consider.
Mr Havercamp is offline   Reply With Quote
Old 11-18-2015, 10:31 AM   #74
Kenny kustom's Avatar
Here is the tsb.
Pays 9 hours, so customer pay will be closer to 12.
The only saving grace, is the fact that it's covered under emissions!!
So that's 8 years 100k miles.
http://www.f150ecoboost.net/forum/at...tsb14-0194.pdf
2015 RAM 3500 CCSB CUMMINS
2016 Sabre 36QBOK
2017 Dynamax Isata 4
Old 11-18-2015, 10:37 AM   #75
x2
Old 11-18-2015, 10:48 AM   #76
X2
Also an F250/350 weighs 1500-1800lbs more. That would drop the mpgs down. Now add that extra weight while towing and you won't get that great performance you do with a lighter 1/2 ton. More mass to move.
goduc is offline   Reply With Quote
Old 11-18-2015, 10:52 AM   #77
Originally Posted by Kenny kustom View Post
Here is the tsb.
2016 Sabre 36QBOK
Holy F#&^$K Batman................
Off topic but I had a 2013 EB Company ride which developed a carbon build up misfire @ 64K.........Dealer wanted $3000+ to repair and Ford was resisting repairing it under any warranty. The Ford zone rep said it would happen again. The company traded it on the 5.0 F150 I am driving now. Curiously two other EB's the company has now have the carbon issue, I believe they are 2014's.
Old 11-18-2015, 11:07 AM   #78
CWSWine's Avatar
Originally Posted by goduc View Post
X2
That was part of my point that many on here say they make more HP and Torque than a V8. Shouldn't they move that large mass better and get better performance than a V8 with lower Torque and HP?
I for one would like it if they would give that option of the EB in the HD's but I don't think we will ever see the current line up of up EB ever put into the HD's. Maybe in the future Ford will develop a EB that can take the duty cycle required in the HD market.
Old 11-18-2015, 11:11 AM   #79
Originally Posted by camperboy View Post
I have a 1 ton right now. My arms can't take the wear and tear of the constant movement of the steering wheel on rough roads.
Then why not spend a few dollars dixing what you have?
donniedu is offline   Reply With Quote
Old 11-18-2015, 11:21 AM   #80
Carbon build up is very common on all direct injection engines.
2016 Sabre 36QBOK
ecoboost, towing
